lower flywheel cover - Pontiac GTO Forum
post #1 of 3 (permalink) Old 11-17-2016, 09:25 PM Thread Starter
where is it? i cant find any lower flywheel cover, ive found the side covers and removed them and then all that connected is the whole oil pan on lower half.. can someone help me cause i have to remove the slave cylinder and install a new one and the book says remove the lower flywheel cover? please help and im not smarter than a fifth grader,lol.
tadelliott is offline
post #2 of 3 (permalink) Old 11-18-2016, 08:00 AM Thread Starter
its for a 2004 gto
post #3 of 3 (permalink) Old 11-18-2016, 12:56 PM
There is no lower cover and no way to replace the slave without pulling the transmission. The slave it located around the input shaft to the trans. When you replace it be sure to install a remote bleeder on the slave before you put it back together. You will thank yourself later.
Picture of one on a Camaro T-56 trans similar to ours.
http://image.camaroperformers.com/f/...e_cylinder.jpg
Where Do I find a Chrome or Polished Aluminum Flywheel Cover??? rvp986 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 6 08-22-2013 08:58 AM
flywheel dust cover Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 6 08-09-2012 08:35 AM
flywheel dust cover Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 1 01-31-2012 03:27 PM
Is a flywheel cover needed on a '64? daveh70 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 10 03-26-2011 08:29 PM
