LS7, clutch disengagement and shims - Pontiac GTO Forum
post #1 of 2 (permalink) Old 03-16-2014, 06:01 PM Thread Starter
Fellas,
Long time lurker, had an LS7 clutch kit, flywheel, slave and TO installed on my 04. No shim. Having an issue where on a flat surface, clutch pedal in, shifting into first results in the car inching slightly forward. General hard shifting when cold.
I know that likely points to a clutch that's not fully disengaging and a shim issue. Do LS7s need shims? Behind the slave? I was under the impression that since the LS7 is self adjusting, they don't need to be shimmed?
Any thoughts? Alternative theory is a bad clutch MC. Car has 155K miles. Did the rev test, clutch in and no movement.
Appreciate the help, would like to go the shop that installed it was a little ammo from you all.
Thanks,
Phil
phillio99 is offline
post #2 of 2 (permalink) Old 04-08-2014, 03:12 PM
sounds like your master cylinder to me
northslider is offline
Ls7 clutch Mddrummer911 Drive train, suspension, alignment and brakes. 1 02-09-2012 09:19 AM
LS7 clutch help cjmcalister Drive train, suspension, alignment and brakes. 4 02-09-2011 07:52 PM
New LS7 Clutch Experience gurvinerjeff Drive train, suspension, alignment and brakes. 11 12-02-2010 01:08 PM
LS7 clutch vs Monster Level 2 clutch POLGTO05 Drive train, suspension, alignment and brakes. 5 05-26-2010 07:18 PM
ls7 clutch unclebens Drive train, suspension, alignment and brakes. 2 08-06-2006 12:50 PM
