Master Cylinder Plunger Issue - Pontiac GTO Forum
post #1 of 6 (permalink) Old 06-29-2013, 10:47 PM Thread Starter
I am having an issue keeping the plunger attached to the pedal. I cant afford for this to snap again. I JUST put this master cylinder in less than 4 months ago and am already stuck.
I get it put on the pedal snug everything looks fine, push it in with my hand see no issue, jump up in the seat and first push just after half way pop!
Unknown1 is offline
post #2 of 6 (permalink) Old 07-01-2013, 07:56 PM
What's coming off? The rod at the pedal?
post #3 of 6 (permalink) Old 07-01-2013, 11:20 PM Thread Starter
Yes. It clips on without issue, seems secure while on the floor and maybe even get one push but then either on the press or depress it pops off.
Last time this happened I had no idea it came off while I was driving. I pushed the clutch in and it broke. Had to tow the car home and replace it. That was a bummer and not cheap!
Unknown1 is offline
post #4 of 6 (permalink) Old 11-14-2013, 06:49 PM
Triple6GTO's Avatar
My plunger actually broke lol. how to fix it
Triple6GTO is offline
post #5 of 6 (permalink) Old 11-15-2013, 12:44 PM Thread Starter
Sadly I had to replace mine again! My advice is replace it with a Tick Performance and have little to no risk of the same issue again.
Unknown1 is offline
post #6 of 6 (permalink) Old 11-15-2013, 07:36 PM
There was an old fix on the other board of using just a zip tie to secure it on. I know it's worked well for some for years. I've carried a couple of ties in the console just on case.
Clutch Master cylinder johnfin Service, Maintenance and Technical Discussion 1 08-24-2013 03:13 AM
clutch master cylinder 04blueskys Drive train, suspension, alignment and brakes. 14 10-13-2011 01:51 PM
Tick master cylinder motoristx Drive train, suspension, alignment and brakes. 9 09-15-2011 02:05 PM
Switch master cylinder Richtenb Drive train, suspension, alignment and brakes. 1 04-15-2010 04:57 AM
master cylinder question 66tempestGT 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 04-12-2010 07:35 AM
