Messed with key fob car not starting! - Pontiac GTO Forum
post #1 of 6 (permalink) Old 12-17-2014, 11:17 PM Thread Starter
So first of all im relatively new to this kind of stuff so excuse my incompetence. The problem started with my key fob's battery dying recently. In an attempt to save some money and not go to a dealer i decided to crack it open and see what i could do. I ended up not being able to get the new battery to take the solder and decided to just let the terminal itself hold it so i could test it out. Not only did the remote not work now the engine wont crank because the immobilizer and ive tried programming the remote twice unsuccessfully. Any help is greatly appreciated guys!
bryanpv670 is offline
post #2 of 6 (permalink) Old 12-17-2014, 11:37 PM
Red1970GTO's Avatar
Fob
Older Key Fobs were pretty streight forward and one could change their battery with no issues. Newer ones not so much. If you use a large ("regular") soldering iron you can easily burn out a diode or other thingie in the remote. A low voltage soldering iron should be used on electronics. The car manufacturers claim the old-style self-programmable remotes were being used to steal cars ... So the car manufacturers changed the remotes to the non-self programmable ones.
Just a guess: You're screwed.
Red1970GTO is offline
post #3 of 6 (permalink) Old 12-17-2014, 11:54 PM Thread Starter
lol yeah i used the right soldering iron its just that im not sure if the remote is even transmitting anything...
post #4 of 6 (permalink) Old 01-16-2015, 09:13 PM
Quoted: 6 Post(s)
When soldering you need to remove the oxy from the surfaces, ie the battery. use 600 grit paper then "tin" the battery out of the unit. Also tin the the other part. Then do a quick solder of the pieces together. Saves the heat buildup. There are 2 methods to program the remote without a tech 2. If you are interested I can post them.
johnfin is offline
post #5 of 6 (permalink) Old 01-16-2015, 09:18 PM
Quoted: 6 Post(s)
p.s. if you hate the stealer like i do, buy a new GM transmitter, $47-53 bucks on ebay, free shipping, comes with a new battery ready to go, just unscrew your key and transfer it, then program it.
johnfin is offline
post #6 of 6 (permalink) Old 06-23-2015, 12:39 PM
Yep! had to do that after the fob buttons deteriorated, easy to program the new ones, and the instructions are on this site. No need to take it to a dealer and pay $100+ for them to do it
Merlinlvmc is offline
Key fob wkendtoy Service, Maintenance and Technical Discussion 36 11-29-2015 02:39 PM
Key Fob Issue jeff613 2004-2006 GTO General Discussion 2 03-12-2013 09:03 AM
05 GTO key Fob, starting issues claremont Service, Maintenance and Technical Discussion 6 01-09-2012 01:37 PM
Key Fob Distance? 06goatm6 2004-2006 GTO General Discussion 19 05-30-2009 05:05 PM
Key FOB Transmitter Programming GM4life Service, Maintenance and Technical Discussion 0 09-27-2008 09:00 AM
