Misfire Cylinder one, but only for 2 minutes when first started - Pontiac GTO Forum
post #1 of 1 (permalink) Old 06-23-2012, 09:19 AM Thread Starter
I have an 04 and when I first start the car up it runs fine for about 5 seconds and then proceeds to run terrible for what I timed at about 2 minutes and then just evens out and goes away and I can drive away. It does this literally every time I start the car. Anyone had this issue?
Things we have checked and tried: Change injector, swapped coils, Noid light on injector connector, new spark plug, new plug wire, checked wires for loose or damaged wires, took ECM out put it in the fridge car ran fine, left ECM in sun car ran like crap like it had been. Any insight would be appreciated. Thanks
gtogooch is offline
06 gto misfire s10ss Service, Maintenance and Technical Discussion 9 01-04-2011 08:48 PM
Gto Misfire KennedyKustoms Engine Discussions 6 04-21-2010 12:11 AM
Hmmm...cylinder 4? Cylinder order??? WanaGTO Service, Maintenance and Technical Discussion 3 07-15-2009 08:07 AM
The pool is closed for 5 minutes Rukee The Lounge 3 01-21-2008 09:33 AM
