mph vs. km/h - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-12-2004, 11:01 PM Thread Starter
bsmcall's Avatar
mph display
Is it just me, or does anyone else find the BRIGHT Green "MPH" in the speedometer panel to be irritating, especially at night???
Has anyone been bothered enough to remove or disable it?
bsmcall is offline
post #2 of 4 (permalink) Old 09-13-2004, 06:01 AM
Take the dash apart and put a small piece of window tint on the inside and it will not be so bright.
2004 GTO is offline
post #3 of 4 (permalink) Old 09-13-2004, 08:57 AM
I heard it described as "Retina searing bright"
The sales guy forwarded it to the Pontiac factory rep as my only suggestion for improvement.
---Larry
LarryM is offline
post #4 of 4 (permalink) Old 12-29-2004, 11:51 AM
I read on another forum that there is a service bulletin (TSB#04-08-49-023) from Pontiac to fix that MPH brightness problem. It is for GTOs built prior to VIN breakpoint 4L299640, so I assume that the ones with later VINs already have that corrected. I was all set to have the dealer fix that before I took delivery of mine, but it has a later VIN, and the MPH indicator is not bright at all, so they must have made a running change on that in production. The fix is for the tech to download the latest "BCM code" and install it on the car's computer.
DuaneGTO is offline
