My AC is not blowing cold air - how much coolant do I need? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-10-2010, 02:07 PM Thread Starter
I'm going to run to Walmart and buy the bottles so that I can try filling this up myself.
My Youtube Channel
Supercharged (Roots) 6.0 GTO
Supercharged (Twin Screw) 3.0 NSX
Supercharged (Centrifugal) 4.3 S-10
batmans is offline
post #2 of 5 (permalink) Old 06-10-2010, 02:26 PM
jpalamar's Avatar
It is very easy. I belive the access port on my car 04 is under the rad cover. Just turn your car on, then turn the AC on high, and hook the bottle to the charge port. Remember to turn the bottle left and right while you fill.
jpalamar is offline
post #3 of 5 (permalink) Old 06-10-2010, 02:43 PM
HP11's Avatar
Quoted: 24 Post(s)
I'd be concerned about two things. Filling from cans, you have no idea how much freon is in the system or what the pressures are and why did it leak in the first place.
HP11 is online now
post #4 of 5 (permalink) Old 06-10-2010, 03:17 PM
FastFrank's Avatar
^^^My sentiments exactly. Overfilling an AC system can be worse than if it's low. You need to have a tech hang a set of gauges on there and see where you are. You could get lucky, and get it to work again by adding freon. But it will eventually leak out again because you haven't fixed the leak. And because there is a leak, your system can draw moisture in through the leak. Which causes other problems.
I would recommend that you not work on your AC system yourself unless you either have the knowledge and equipment, or can afford to pay someone to fix what you mess up. Which is almost always more than it would have cost to pay someone to fix the original problem.
2004 Yellow Jacket M6
FastFrank is offline
post #5 of 5 (permalink) Old 06-10-2010, 03:50 PM Thread Starter
good point.
the systems that I have seen have pressure gauges built in.
My Youtube Channel
batmans is offline
A/C seems weak and isnt blowing very cold. Anyone have similar problems before? justin-branam Service, Maintenance and Technical Discussion 17 07-30-2009 08:50 AM
Cold Air Intake chucksgto Intake and Exhaust Discussions 6 02-06-2009 04:39 PM
true cold air 1gto Intake and Exhaust Discussions 8 12-06-2006 03:52 PM
cold air nagoat 2004-2006 GTO General Discussion 10 10-29-2006 01:04 AM
