My Brake Resivoir is E-M-P-T-Y! - Pontiac GTO Forum
post #1 of 4 (permalink) Old 12-31-2004, 08:16 PM Thread Starter
Yikes!!!
Just discovered this. Can I just add to it to bring it to 'Full' when cold?
Or does the system need to be bled then added?
Thanks for your replies.
Last
Last is offline
post #2 of 4 (permalink) Old 12-31-2004, 08:44 PM
Send a message via Yahoo to dctex99
Originally Posted by Last
Yikes!!!
Last
From other posts on here previously,,,they all advised bleeding and flushing the whole system with Valvoline Synthetic Brake fluid and refilling,,,you will have better brakes also!!!
dctex99 is offline
post #3 of 4 (permalink) Old 01-01-2005, 12:17 AM
If it's completely empty you probably have air in the system and they need to be bled. If there's air in the system the pedal will go to the floor and the car won't stop. Very important to find the cause of the empty resevoir.
Skidmark is offline
post #4 of 4 (permalink) Old 01-01-2005, 09:39 AM
Xman's Avatar
Better find out what caused the leak down to occur while you are bleeding the brakes. Definitely use the Valvoline Synthetic!
Xman is offline
