need help getting the right speedometer cable gear - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-07-2006, 02:17 AM Thread Starter
hi my 67 gto is a few hours away from being done ,i drove it and speedometer is at least 40mph off ,i have a turbo 400 trans and a 455 rear end gear o belive , just need some place to start on how to get right speedo gear and tires are big mickey tompson 15" all help or links is appreciated
ergo is offline
post #2 of 3 (permalink) Old 05-07-2006, 07:51 AM
First you need to get the ratio of how far it is off.
For a gear change only then you can divide the new gear by the old gear- for example 4.55/3.55 would be 1.28
For changes to a combination of things such as trans, gear and tires then the easiest way to get the error is to drive the car. What I've done is to use highway mile-markers to figure out the speedometer reading that it takes to go 1 mile in 1 minute, or 5 miles in 5 minutes, etc. (which corresponds to 60 MPH). Divide this number by 60 to get the error- for example if your speedo reads 78 MPH at an actual speed of 60 MPH, then divide 78/60 and you get 1.3
Pull the speedo gear you have and count the teeth on it. Then multiply the number of teeth by the error that you calculated to get the number of gear teeth that you need. As a check, if your speedometer is reading too high then you will need more teeth on the speedo gear.
Walt
06 Impulse blue, M6, 17"
69 LeMans vert, stock-looking 455-powered "sleeper"
74 455 TA, HPP magazine cover car
PontiacGuy is offline
post #3 of 3 (permalink) Old 05-07-2006, 09:04 AM
Here is a Speedometer Gear Usage Chart for 67.
http://www.teufert.net/speedo/67-400-gt.htm
05GTO is offline
