Need Predator help for 05 GTO - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-16-2006, 11:50 PM Thread Starter
QSGTO's Avatar
I'm not sure how to adust wide open throttle with the predator. Should I make it richer or leaner? stock engine with Diablo Tune and K&N air filter in air box.
QSGTO is offline
post #2 of 3 (permalink) Old 01-18-2006, 04:49 PM
Im a little out of your area but the guys that work on my goat know alot about working with the preditor.
Dyno Tuned Performance 757-549-3966 you can talk to Frank or Brent but Brent does most of the Tuning
Braman'sGTO is offline
post #3 of 3 (permalink) Old 01-18-2006, 06:13 PM
I wouldn't recommend making changes like that unless you were on a dyno with an O2 sensor. You could do SERIOUS damage to your engine by adjusting a/f ratios. I don't know if there's enough leeway in the predator's tuning to do much damage, but it can be quite dangerous for an untrained person to mess around with such things.
baron_iv is offline
