Need some expert opinions.... - Pontiac GTO Forum
post #1 of 18 (permalink) Old 06-05-2010, 10:28 PM Thread Starter
I'm the second owner of an 06 CGM GTO, with a manual transmission. I've had it for 3 days, it's a certified GM car. 12mo/12kmile bumper to bumper warranty.
When it's cold, and I start it up...it makes a crazy whining noise, almost like it's trying to gain pressure somewhere. It will do it several times before it stops. When the car is warm, it doesn't seem to do it.
Today it also did another funky thing. I went to lock the car, and the horn beeped very strangly. It was like the horn blew twice very quickly. The drivers side door locked, and the passenger side door didn't. I tried to press the lock button several times, and it followed by the horn blowing again. I opened the passenger door, and the alarm sounded. The car horn has never blown when I lock the doors before. I found it very strange. After I hit the unlock button, the alarm quit....and I got in the car and started it up, and shut it back off, got out...and hit the lock button and it locked both doors fine. Whats the deal with that? Anyone ever have a similar experience?
I appreciate any comments on the matters above.
keithd06 is offline
post #2 of 18 (permalink) Old 06-06-2010, 09:14 AM
johni53's Avatar
Probably is your door locks. Mine were loose and when I tried to push the passenger lock it stuck and I got the 3 quick beeps from the horn when I tried unlocking. They need to be set properly in the door so they lock and unlock without sticking. I would even get the 3 beep alarm and the car would tell me "alarm activated by hood" after the lawn crew mowed close by at my office. Apparently these cars' alarms are pretty sensitive.
johni53 is offline
post #3 of 18 (permalink) Old 06-06-2010, 09:24 AM
The first problem is hard to diagnose on the internet. The second one is definitely your door lock actuator. It's a fairly common problem. It sounds like it's intermittent right now but you'll probably have to have it replaced when it starts acting up again. The beeps are just telling you your door didn't lock. If it does it just manually lock the offending door and then use the key on the other one until you can get it fxed
post #4 of 18 (permalink) Old 06-06-2010, 10:08 AM
Did you read the owners manual? There is a way to "personalize" the car's settings, including locking and unlocking both doors at the same time with the fob (called Two Stage Unlock) and doing away with the horn beeps when locking the car.
Also, if you lock the doors with the remote, then open them with the key the alarm will sound.
Poncho Dan is offline
post #5 of 18 (permalink) Old 06-06-2010, 10:30 AM Thread Starter
I appreciate the feedback.
I'm going to see if the video camera on my droid will capture the noise that I'm talking about, and post it. I did a lot of reading lastnight, and I believe it's either the alternator bearing, or the water pump.
keithd06 is offline
post #6 of 18 (permalink) Old 06-06-2010, 10:38 AM
I get belt squeel all the time when it's humid upon startup.
post #7 of 18 (permalink) Old 06-06-2010, 11:25 AM
Gotagoat's Avatar
It may be the sound of your air intake. Listen to some the Utube videos of GTOs being started (usually found by searching the exhaust forum) see if the sound you hear on the video is the same as yours is making.
Gotagoat is offline
post #8 of 18 (permalink) Old 06-06-2010, 12:11 PM
GM4life's Avatar
Hard to tell what the whine is. I have a faint alternator whine when I first start it up then it goes away after a few mins.
Your door lock acturator is bad. If you try to lock the door and it does not lock followed by four simultaneous horn honks, thats the problem for sure.
GM4life is offline
post #9 of 18 (permalink) Old 06-08-2010, 08:09 PM Thread Starter
If anyone is interested in trying to diagnose this hydraulic like noise I'm talking about....shoot me a PM with your email, and I'll send you a video of the elusive noise.
I can't figure out how to attach the video to the thread.
keithd06 is offline
post #10 of 18 (permalink) Old 06-09-2010, 02:45 PM
FastFrank's Avatar
You can host the video on photobucket, then insert a link in this thread.
2004 Yellow Jacket M6
FastFrank is offline
2 Goats swapping transmissions, expert help needed danieloneil01 Drive train, suspension, alignment and brakes. 17 05-05-2010 02:59 PM
Found a 70 Orbit Orange GTO...expert help? jacksgto 1964-1974 Tempest, Lemans & GTO General Discussion 17 12-27-2008 02:43 PM
Expert Opinions Please Koppster 1964-1974 Tempest, Lemans & GTO General Discussion 16 11-25-2008 07:59 AM
opinions? GTO_400 2004-2006 GTO General Discussion 0 01-23-2006 06:09 PM
Ask the GTO Expert b_a_betterperson The Lounge 1 07-12-2005 07:20 AM
