Never seen this problem before... - Pontiac GTO Forum
post #1 of 12 (permalink) Old 01-04-2006, 08:05 PM Thread Starter
Justice's Avatar
Send a message via Yahoo to Justice
I *CAN'T* fill my tank up. Try as I might, the pump shuts off and I can see the fuel just below the filler, but my gauge reports I'm only at of a tank and it seems to be getting worse. When I first bought the car, I noticed I could only get it to 7/8ths, but now it's stopping at . Is there a TSB on this or does anyone have any ideas? Thanks!
Justice is offline
post #2 of 12 (permalink) Old 01-05-2006, 06:24 AM
Have you been using the same pump or same gas station? It sounds like the vapor recovery systems on the pump and car are fighting each other. I'm not an expert on this, but it does sound like a vapor recovery problem. Anyone else chime in on this one?
Pennsylvania Goat is offline
post #3 of 12 (permalink) Old 01-05-2006, 06:43 AM
johnebgoode's Avatar
I know some cars have faulty clusters. Maybe this is part of that problem...?
johnebgoode is offline
post #4 of 12 (permalink) Old 01-05-2006, 08:13 AM
GTODEALER is offline
post #5 of 12 (permalink) Old 01-05-2006, 11:24 AM
There is a fuel calibration that has to be programmed into the cluster to indicate the fuel capacity and fuel sender resistance. Odds are it has the wrong calibration. I'd take it to the dealer and have them fix it.
edysinger is offline
post #6 of 12 (permalink) Old 01-05-2006, 11:38 AM
Make : PONTIAC Model : GTO Year : 2004
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Num : 050849003 Date of Bulletin: JAN 01, 2005
NHTSA Item Number: 10013486
Component: ENGINE AND ENGINE COOLING
Summary:
SPEEDOMETER ERRATIC MOVEMENT FUEL GAUGE DOES NOT GO TO FULL AFTER FILLING ENGINE COOLANT TEMPERATURE GAUGE READS HOT AND COOLANT TEMPERATURE LIGHT ILLUMINATES. *EH
05GTO is online now
post #7 of 12 (permalink) Old 01-05-2006, 08:26 PM
I have the same problem. I am in So Cal where they have those vapor recovery hoses on the Gas Pumps, and I think that is the problem. I have to pull the black part of the hose up and go slow for the last 2 - 3 gallons to go in the tank. Hope that helps.
GTOBert is offline
post #8 of 12 (permalink) Old 01-16-2006, 12:21 PM
I had absolutely no problems filling up until I read this post - now mine will only fill up to 3/4 of a tank. Last two fill-ups stopped at 3/4. I'll try another one or two before looking for a solution.
jontyrees is offline
post #9 of 12 (permalink) Old 01-16-2006, 01:32 PM Thread Starter
Justice's Avatar
I have a solution but I have to draw a picture for it. I'll post again with what I had to do to FILL up.
Justice is offline
post #10 of 12 (permalink) Old 01-16-2006, 01:50 PM
there is a tsb on this, take it to your dealer for a new dash cluster
the3car is offline
