New 04 gto auto owner kind of paranoid - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-24-2011, 10:59 PM Thread Starter
Hello I am new to the gto and v8 scene I have 34000 miles on it Ive put a outer tie rod and alignment also rear pads and rotors. But the rotors make a whine while movement, replaced the rotors and noise disappears? I have replaced the antifreeze and gear oil, rear diff makes a slight chatter? Any advice or pointers what to look out for is greatly appreciated thank you.
04ls1GTO is offline
post #2 of 4 (permalink) Old 03-26-2011, 09:02 PM
look out for cops... lol I've taken mine from 27-70k and have had no major issues with it yet! I love this car more than my left hand
Lord Adam - The - Magnificent
ASmittie is offline
post #3 of 4 (permalink) Old 03-26-2011, 09:06 PM
YellO5LS2's Avatar
When you changed the fluid in the differential did you add the GM limited slip additive? Without it the gears will make noise. You're not hurting anything so don't worry, but get the additive ASAP from a GM dealer to fix the "slight chatter."
Do the rotors whine really loudly? only when brakes are depressed or all the time? That sound more like an adjustment issue in the calipers to me. See if there's more noise on one side than on the other, or if one wheel is worse than all.
YellO5LS2 is offline
post #4 of 4 (permalink) Old 03-26-2011, 09:07 PM
YellO5LS2's Avatar
Is your car an auto? I need my left hand in mine to hold the wheel while i shift :-P Like the quote though.
What Kind Of Car Did You Get Rid Of For Your Gto? 227 2004-2006 GTO General Discussion 320 07-11-2016 07:08 PM
What kind of heads should i get for gto? 1969gtojohn 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 05-01-2008 10:21 AM
Kind of a shake... ??? And kind of a squeak. porterusaf 2004-2006 GTO General Discussion 5 01-23-2007 10:14 PM
