Non-start issue - Pontiac GTO Forum
post #1 of 6 (permalink) Old 08-17-2015, 11:05 AM Thread Starter
Quoted: 6 Post(s)
Non-start issue
Could you say that there is one issue, more then any other issue that is the culprit for a non start issue on these cars? I am going to guess and say that the ignition switch is up on the list.
johnfin is offline
post #2 of 6 (permalink) Old 08-17-2015, 01:23 PM
I would guess a hot starter solenoid as a main no start issue. Many replacments were done without using the heavy duty solenoids pontiac used and the exaust heat shield was often discarded. Headers agrivated the situation even more.
67post coupe is offline
post #3 of 6 (permalink) Old 08-17-2015, 07:00 PM
What's the symptom? Does it crank? Does it fire at all and then die?
post #4 of 6 (permalink) Old 08-18-2015, 12:45 PM Thread Starter
Quoted: 6 Post(s)
dies
Cranks just fine. No start. Wait a while, wiggle key and steering around then it starts. I am thinking the key cylinder or BCM
johnfin is offline
post #5 of 6 (permalink) Old 08-18-2015, 01:42 PM
If it's wiggling the key the cylinder would be my first guess or wiring up there. The BCM shouldn't be affected by that and a key FOB contact problem will make it fire and then die in a couple of seconds if the VATS isn't satisfied.
post #6 of 6 (permalink) Old 08-19-2015, 07:23 AM Thread Starter
Quoted: 6 Post(s)
key
Is the spring return for the key in the cylinder assembly or somewhere else. Seems like the key gets stick sometimes in the start position.
johnfin is offline
Electrical Issue in Dash/ Won't Start 66 GTO Indecision 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 5 09-19-2014 10:39 PM
Help on start-up... Instg8ter 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 05-03-2011 07:52 AM
I'll Start it... Zrocket The Lounge 6 12-28-2009 09:53 AM
Start Issue raspantienator 2004-2006 GTO General Discussion 7 08-27-2008 07:03 AM
Start Issue raspantienator 2004-2006 GTO General Discussion 5 08-20-2008 04:15 PM
