Not idling properly - Pontiac GTO Forum
post #1 of 12 (permalink) Old 11-18-2010, 01:51 PM Thread Starter
Not idling properly
I've got an 04 and recently it is not idling correctly jumping from normal to less than 250RPM and then back up and i need to keep my foot on the gas to keep it running when im stopped, whats up?
BLUE04 is offline
post #2 of 12 (permalink) Old 11-18-2010, 01:55 PM
jpalamar's Avatar
Could be a number of things, exhaust leak, bad 02, plug, wire, vac leak, dirty maf, ect.
jpalamar is offline
post #3 of 12 (permalink) Old 11-18-2010, 02:03 PM Thread Starter
Last summer I put in ceramic coated LT headers and an SLP loudmouth exhaust with no cat....could that burn up O2 sensors?
BLUE04 is offline
post #4 of 12 (permalink) Old 11-18-2010, 02:05 PM Thread Starter
And an Airforce one cold air intake
BLUE04 is offline
post #5 of 12 (permalink) Old 11-18-2010, 07:38 PM
jpalamar's Avatar
Front O2 helps the engine run, the rears(after the cat) only test your cats. Chances are since you have no cat, your rear O2 is turned off so even if they somehow were damaged, it wouldn't matter.
jpalamar is offline
post #6 of 12 (permalink) Old 11-18-2010, 08:28 PM Thread Starter
? My buddy has a scanner and it said multiple mis fires and gave a P0300 code with no indication of which cylinder it was running like crap all the way there and when i left i was half way back home and it started running fine..
BLUE04 is offline
post #7 of 12 (permalink) Old 11-18-2010, 09:24 PM
I suspect a vacuum leak. Or bad ignition module?
Poncho Dan is offline
post #8 of 12 (permalink) Old 11-19-2010, 02:02 AM
87GN06GTO07IRL's Avatar
Bad idle air control in the t/b?
87GN06GTO07IRL is offline
post #9 of 12 (permalink) Old 11-19-2010, 07:11 AM Thread Starter
Drove it again today and it started doin the same thing and then it fixed itself....
BLUE04 is offline
post #10 of 12 (permalink) Old 12-12-2010, 09:45 AM
I've only had my GTO about a month so I don't know if this helps. Maybe throttle position sensor? My SRT-4 did something similar and the wiring to the tps was bad.
Ls2Brew is offline
Question about idling and our OEM ram scoop on the hoods..... pctek 2004-2006 GTO General Discussion 2 07-29-2010 02:27 PM
Didnt really store car properly, Should i worry? Lapres_3 2004-2006 GTO General Discussion 5 01-16-2010 04:07 PM
Are your tires properly inflated??? fergyflyer The Lounge 6 04-24-2008 02:57 PM
Very good post about using your clutch properly Bandit The Lounge 5 04-08-2007 12:13 AM
How to take off properly without sliding? joeyk97 Racing and Kill Forum 26 02-02-2007 01:42 PM
