O2 sensor disables - Pontiac GTO Forum
post #1 of 6 (permalink) Old 11-23-2010, 09:30 AM Thread Starter
O2 sensor disables
How do you disable the O2 sensors that go behind the cats, I put full exhaust on my car with no cats...do they still need to be there or can you just unplug them?
BLUE04 is offline
post #2 of 6 (permalink) Old 11-23-2010, 12:43 PM
87GN06GTO07IRL's Avatar
If you Hp tuners you can turn them off yourself. If not ask someone that does or go to a shop that can do it.
87GN06GTO07IRL is offline
post #3 of 6 (permalink) Old 12-07-2010, 01:32 PM
what symptoms do you get if you dont turn them off. what ses lights will it trigger?
lingenfelter cai, vararam tb spacer, v/max ported tb, livernoise stage 2 heads with comp cam 232/232/.50 114 lsa. slp 1 3/4 headers high flow cats, x pipe, qtp cut outs, flowmaster mufflers. tuned by tt performance , highly recomended in n.j.
NEXSTAR7 is offline
post #4 of 6 (permalink) Old 12-08-2010, 08:14 AM
jpalamar's Avatar
Rear O2s only test your cats. If you dont' have any or the sensors go bad, it will through a CEL. It will not effect how your car runs, only the fornt O2s do that. Since you did a full exhaust, you might wanna get your car tuned. I would assume your running rich right now and your tuner can disable the rear O2s.
jpalamar is offline
post #5 of 6 (permalink) Old 12-09-2010, 10:28 AM Thread Starter
I got a code for multiple mis fires and was told that could be the problem then I took it in and they said I had 3 bad ignition coils...I replaced only the 3 bad ones with no result...should I do the rest with new spark plugs?
BLUE04 is offline
post #6 of 6 (permalink) Old 12-09-2010, 06:33 PM
You could use simulators too, but any tune you'd get would fix it also.
Poncho Dan is offline
66 water sensor xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 09-10-2010 09:04 AM
throttle sensor?? clay 2004-2006 GTO General Discussion 13 12-31-2009 06:01 PM
o2 sensor. rj91049 Intake and Exhaust Discussions 5 10-25-2009 07:13 AM
maf sensor NEXSTAR7 Service, Maintenance and Technical Discussion 2 07-22-2007 07:30 PM
Clutch Sensor GTO JUDGE 2004-2006 GTO General Discussion 9 09-28-2006 11:07 AM
