oil - Pontiac GTO Forum
post #1 of 7 (permalink) Old 09-03-2008, 02:34 AM Thread Starter
oil
hey guys just changed my oil the other day and the change oil thing still comes out any idea how i can reset that?
jradke123 is offline
post #2 of 7 (permalink) Old 09-03-2008, 05:54 AM
How to Reset the Engine Oil LifeSystem
The Engine Oil Life System calculates when to change
the engine oil and filter based on vehicle use. Anytime
engine oil is changed, reset the system so it can
calculate when the next oil change is required. If a
situation occurs where you change your oil prior to
the Service Engine Oil light being turned on, reset
the system.
1. With the engine off, turn the ignition key to ON.
2. Fully press and release the accelerator pedal slowly
three times within five seconds.
3. Turn the key to LOCK.
If the Service Engine Oil light comes back on when
you start your vehicle, the engine oil life system
has not reset. Repeat the procedure.
post #3 of 7 (permalink) Old 09-03-2008, 06:16 AM Thread Starter
hey thanks a lot im gonna try that in a min ha that lil beeping sound was just so annoying thanks
the system.
post #4 of 7 (permalink) Old 11-01-2008, 06:22 PM
rnoswal's Avatar
I have to press my gas pedal 5 or 6 times before it resets for some reason. 3 won't do it......Weird!!!
rnoswal is offline
post #5 of 7 (permalink) Old 11-01-2008, 06:33 PM
alsgto04's Avatar
My brother has an 06 gto and he also needs to step on it like 5 times to reset it and on mine which is an 04 i only have to do it 3 times. It is kind of weird.
alsgto04 is offline
post #6 of 7 (permalink) Old 11-02-2008, 04:50 PM
Pump it 5 or 6 times?? OMG!!! You're gunna flood it out!!
post #7 of 7 (permalink) Old 11-03-2008, 11:00 PM
rnoswal's Avatar
It's even worse when I pull out the choke lever!....lol
rnoswal is offline
Oil Change Intervals GTO JUDGE Service, Maintenance and Technical Discussion 2 09-30-2007 01:33 AM
Peak Oil Myth Debunked b_a_betterperson The Lounge 3 11-24-2006 11:01 PM
Oil Analysis FastFreddy Service, Maintenance and Technical Discussion 5 06-10-2006 10:23 AM
laugh for the day 170FC The Lounge 6 10-19-2005 12:29 AM
We're Not Running Out Of Oil b_a_betterperson The Lounge 6 08-24-2005 06:15 AM
