oil - Pontiac GTO Forum
post #1 of 6 (permalink) Old 11-10-2015, 09:25 PM Thread Starter
oil
Had a question my 06 gto has 80000mi did a oil change maybe about 6months ago used redline but today dash beep with service engine oil but hadnt been close to 3000mi so i checked oil and needed 2quarts could it be burning oil
uoseguera23 is offline
post #2 of 6 (permalink) Old 11-11-2015, 07:37 AM
SANDU002's Avatar
What weight oil? Unless you are tracking it all the time, use a 5w-30 synthetic. Also did you tap the gas pedal 3 times when you last changed the oil. The manual says tap twice which is wrong.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #3 of 6 (permalink) Old 11-11-2015, 10:09 AM
Gotagoat's Avatar
In addition to above comment, did you check for the proper oil level immediately after it was changed? Unless you changed it yourself, it's not prudent to assume the proper amount of oil was put in your engine. I can't count the number of times over the past 50 years that I've discovered oil shortages after a change. Some people hired to do oil changes "think" all engines require four quarts.
Gotagoat is offline
post #4 of 6 (permalink) Old 11-11-2015, 10:12 AM Thread Starter
To be honest i have no manual for the car so i did not know that thank you for that information as far as it burning oil how would i tell i dont take to the track it has a couple mods and yes i use 5w30 redline on it
post #5 of 6 (permalink) Old 11-11-2015, 11:17 AM
HP11's Avatar
Quoted: 24 Post(s)
Originally Posted by uoseguera23 View Post
To be honest i have no manual for the car ......
2006 Owners Manual
HP11 is offline
post #6 of 6 (permalink) Old 11-11-2015, 04:18 PM Thread Starter
Thank you for that manual
Low Oil Pressure-Bad Oil Pump PontiacJim 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 09-23-2014 03:03 PM
Low oil pressure/oil light coming on etewald 1964-1974 Tempest, Lemans & GTO General Discussion 8 01-26-2013 08:16 PM
Recent oil change n seems like oil level creeps higher?..... pctek Service, Maintenance and Technical Discussion 2 09-27-2010 09:58 PM
Truck, SUV oil vs. car oil?? Zebra Engine Discussions 5 12-03-2006 09:50 PM
