Oil Consumption ... yet again!! - Pontiac GTO Forum
post #1 of 12 (permalink) Old 09-04-2008, 10:53 AM Thread Starter
So, I've really not had much of a problem with oil consumption. I would lose .5 to a full quart between changes. I use synthetic Mobil 1 5-30, with a simple Autozone filter/Fram filter.
2 weeks ago, my check engine light comes on while at a gas station. So I pop the hood, and I'm low almost 3 quarts on oil . Yesterday, I check, and I'm down yet again, 2 quarts.
That means, that since my last oil change, my Goat has consumed almost the entire oil supply!!!
I know that LS2's are a little hungry for oil, but 5 quarts, anyone got some input? The car only has 27k on it, and is a 06, 6 speed.
exwrx is offline
post #2 of 12 (permalink) Old 09-04-2008, 11:29 AM
Gotagoat's Avatar
My 05 M-6 18K uses no oil between changes. You definitely have a problem.
Gotagoat is offline
post #3 of 12 (permalink) Old 09-04-2008, 11:35 AM
alsgto04's Avatar
Make sure its not leaking it or maybe the oil filter is not on right jack it up remove the plate and see if theres leaks around the oil pan.
Goog luck.
alsgto04 is offline
post #4 of 12 (permalink) Old 09-04-2008, 12:04 PM
Has the car any MODS?? Bad PCV? Aftermarket valve covers or removed baffle under the PCV?
post #5 of 12 (permalink) Old 09-04-2008, 08:33 PM Thread Starter
It's completely stock, except for the silencer delete, and aftermarket "bling" oil cap. I don't think it's the cap, as there is no oil leaking from, or around it, and I've never had this problem before.
There also is no leak, neither under, on top, or anywhere in the engine compartment. I'm doing another oil change tomorrow, and will be monitoring the oil level closely. Last time I took my car to the dealer for warranty work, i got it back with 50+ miles tacked on, and burned rubber all over my rear fender. Someone had a good time on my dime. GM did nothing, even with the complaint I filed, though the dealer did call me to confirm the complaint. No follow up on their part.
I've done all the maintenance myself, and am aware of these things inhaling oil when engine braking.... but even with track days... I've never lost 5 quarts before. It runs fine, no funny noises, smoke, smells, power loss, or any other tell-tale signs of internal damage.
exwrx is offline
post #6 of 12 (permalink) Old 09-06-2008, 03:15 AM Thread Starter
Did my oil change... the bottom is as clean as the day I bought it. I'm a neat freak.... so I keep my engine spotless. No oil anywhere.
It took 6 quarts of oil... usually only needs 5-5.5. Interesting, but maybe I'm being paranoid. Filled the tank, and will check again once it's empty.
exwrx is offline
post #7 of 12 (permalink) Old 09-06-2008, 07:22 AM
The only thing I can think of (besides the PCV) that would consume that much oil without leaking would be a broken piston. I hope that's not the case!
post #8 of 12 (permalink) Old 09-30-2008, 09:26 PM
The intimidator's Avatar
Have you tried to check the rear main seal? my 06 had a slight leak in that area, got it changed no leak. If it is a piston going bad, pull the plugs and examine them. Not to scare you check the radiator for oil slick in the coolant. For a good oil filter get a k&n oil filter .
The intimidator is offline
post #9 of 12 (permalink) Old 10-03-2008, 10:25 AM Thread Starter
Had it checked with me watching like a Hawk. Went through all possible scenarios. Checked Coolant for oil, plugs for fouling, pulled the MAF and Filter to check the inside of the intake, had the guy do a compression test, as well as pull the injector/fuel rail to see if there were any shenanigans happening in the valve train..... nothing.
It's as good as new. My mechanic isn't sure were it went, but considering track days, and a longer than usual oil change interval.... 4 mo's, he's not really sure that I should be worried. It hasn't lost "ANY" oil since, is running like new, and has no obvious problems.
I also talked to another GM service mechanic, and heard a similar story, that several of the LS2 powered cars (Trailblazer, Vette, Escalade) on some oil changes would come in very low on oil. If relying on the Oil service indicator, many would be low up to 3 quarts by the time they bring them in. His response/diagnosis, as well as GM official stand on the issue is that during engine braking, a tremendous amount of oil finds its way into the chamber because of the vacuum created by the pistons leaving TDC without a big burn.
So far, with no more engine braking, I've lost no oil. What he said... seems to make sense, though I never know with service guys.
exwrx is offline
post #10 of 12 (permalink) Old 10-11-2008, 01:21 AM
vxssls1's Avatar
Send a message via MSN to vxssls1
did you change oils
some LSx's tend to use more oil with different brands/grades of oil
I personally use thicker oil and so do most guys over here in AU
222/224 112
241 ported heads 11:1
comp 918's
OTR
25% UDP
ported TB
4 into 1's 1 5/8,3"cats,twin 3" X force
M6,ripshifter
[email protected],390rwhp
vxssls1 is offline
Oil Change Intervals GTO JUDGE Service, Maintenance and Technical Discussion 2 09-30-2007 01:33 AM
Oil Consumption Letter from GM GTO JUDGE Service, Maintenance and Technical Discussion 45 07-23-2007 07:27 PM
Peak Oil Myth Debunked b_a_betterperson The Lounge 3 11-24-2006 11:01 PM
laugh for the day 170FC The Lounge 6 10-19-2005 12:29 AM
We're Not Running Out Of Oil b_a_betterperson The Lounge 6 08-24-2005 06:15 AM
