Oil Filter - Pontiac GTO Forum
post #1 of 13 (permalink) Old 05-01-2006, 02:30 PM Thread Starter
Oil Filter
It looks like our 2005 GTO takes a PF46 filter. The local tells me that this is the only filter recomended for the LS2. The local speed shop suggests using the PF59, which they say is the same filter with the same featues only longer with more capacity and filtering ability. Does anyone have any thoughts on this. Does the larger filter provide more capacity and filtering and help cool the oil a little? Or... if we are changing oil every 3,000 is the PF46 really all you ever need. Not a big deal, just wondering. Thanks.
GTO-Quikls2 is offline
post #2 of 13 (permalink) Old 05-01-2006, 03:13 PM
While it's under warranty, I would go with the stock filter- - -don't give them any ammunition.
noz34me is offline
post #3 of 13 (permalink) Old 05-01-2006, 04:43 PM
Go with the correct one. Depending on how long this other filter is, you may want to check if it is not too long as to interfere with the skid plate.
Don't always go by those guys in parts places. A lot of them pretend like they know all.
post #4 of 13 (permalink) Old 05-01-2006, 06:37 PM
I had one of them in the Autozone tell me how the 400 in my Trans Am came out of the truck Pontiac made.
Taxman is offline
post #5 of 13 (permalink) Old 05-01-2006, 07:29 PM
UdnUdnGTO's Avatar
PF isn't that a Fram number? Hey, check your different filters, there are better ones than that. Sure pay a little more, but get the protection. KN makes an excellent filter. So does Amzoil. Lots of good stuff out there, look around
UdnUdnGTO is offline
post #6 of 13 (permalink) Old 05-02-2006, 06:05 AM
Wizard Of Iz's Avatar
Not Fram
No ... PF46 is NOT a Fram number. It is the correct number for the AC Delco filter for our Holden/GTO's and is actually a good filter.
To read up on filters .... read hereOil Filter Study
"I've made enough money to buy Miami but I've pissed it away so fast." - Jimmy Buffett
'15 Dodge Challenger SRT, B5 Blue, M6
'17 Dodge Durango R/T, Granite Crystal, A8
'05 Pontiac GTO, MBM, A4 - SOLD November 2013
Wizard Of Iz is offline
post #7 of 13 (permalink) Old 05-02-2006, 07:31 AM
They don't make the PF59 any more. Thats the filter that came on my 01 Sierra with a 5.3. As of my last oil change I couldn't get that filter any more, they started using the PF46 in the 5.3 in 2002 I guess. Makes it easy for me to remember - the same filter goes in my Goat and my Truck.
The 59 is quite a bit longer than the 46, so it did make me upset that they stopped making it.
Grey-Goat is offline
post #8 of 13 (permalink) Old 05-02-2006, 09:35 AM
I switched to the K&N oil filter on my first oil change along with Redline lubricants. I've had great results with the K&N with past racing engines and I drive my goat hard.
roadracer is offline
post #9 of 13 (permalink) Old 05-02-2006, 10:04 AM Thread Starter
The longer filter will fit under the skid pan... I checked that one... but I think I will stick with the PF46 for now anyway. There are still PF59's on the shelves here. I know what you mean about the auto part stores. We have a good on here but even at that, they told me that a replacement for the PF59 was the PF58. Well, the PF58 does not have the anti drain back valve. I've never used the K&N but I did have a Mobil 1 and Fram split a seam on me and leak oil. I've always had good luck with the AC so for now, PF46 it is. Thanks all.
post #10 of 13 (permalink) Old 05-02-2006, 03:56 PM
I use the PF46 along with Royal Purple, never had a problem yet.
1BadGoat is offline
