Oil Filters/Synthetic Oil - Pontiac GTO Forum
post #1 of 12 (permalink) Old 05-03-2013, 08:45 AM Thread Starter
I have just recently purchased an 06 GTO and have worked in the auto parts world for the last 15 years. I wanted to clear up some of the myths regarding different brands of oil filters. Last time when the WIX representative came into our store, I had him cut open every brand and type of filter we sell to compare their internal differences. From what I've seen, I will never use a Fram of any grade or anything cheaper/generic than Fram.
All 3 versions of Fram XG, TG, HM filters and our house brand made by Fram used about half the pleats of filter media than the other filters. Also, disturbingly, they are the only ones to use cardboard top and bottom caps on the filter media which are cheaply glued together. Some of them even had areas where the glue didn't fully seal and you could see right through the filter. Their bypass valve was very cheap rubber and the spring at the top was a cheap piece of stamped steel. When cut apart, their cases feel flimsy and thinner than the others.
The AC Delco, Motorcraft, Bosch, Mobil 1, and K&N all had many more pleats that were tightly weaved and used steal top and bottom caps. Their bypass valves were much more pliable rubber and won't dry out as quickly from heat and time. They still all used the stamped steel spring but was of higher thickness.
The WIX filter is the only one to use a dedicated anti-backflow valve, and a steel coil spring instead of the stamped steel one. They also had the tightest pack of pleats of filter media. They are also about half the price of the K&N or Mobil 1. The only thing that really makes the K&N stand out is the fact it has the 1" nut on the bottom for easier removal on some applications and the case is thicker than the others for higher burst strength in extreme high performance applications.
In my opinion, run the slightly longer WIX 51522 or if price don't matter use the Mobil 1 M1-206, K&N HP2006 or the Amsoil EAO64. The extra filter media will increase efficiency and flow rates slightly.
Hope this helps, Greg
fastestsvx is offline
post #2 of 12 (permalink) Old 05-03-2013, 09:06 AM Thread Starter
Synthetic Oils
As for oil qualities go, I had the oil rep do the bearing failure test on most of the name brand synthetics we stock in 5W30 to see which one holds up the best. This test doesn't test all aspects of oil but gives an indication of what oils coat and lubricate the best under extreme conditions...
I am by no means a big believer in Royal Purple but their oil did perform the longest before it locked up.
2nd Castrol Titanium
3rd Mobil 1 (not EP or Hi Mi)
4th Castrol Syntec
5th Valvoline SynPower
6th Pennzoil Platinum
The time between these failures were very close, some within a few seconds of each other so all of them are very close. I don't have exact times, we just wrote down longest to shortest times.
I am a fan of and use Amsoil (I'm from WI where its made) which I wish we could've tested and compared. From what I understand, it should easily surpass Royal Purple.
post #3 of 12 (permalink) Old 05-03-2013, 09:31 AM
68greengoat's Avatar
I started a new thread for you rather than have you post to an old thread......
Just curious, you say you're from WI, but your IP has you located out in Arizona. When did you leave WI?
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #4 of 12 (permalink) Old 05-03-2013, 07:21 PM
There may be nuances in oil but I doubt anyone will ever see an oil related engine failure if they change it regularly. The filter however is more important.
post #5 of 12 (permalink) Old 05-03-2013, 07:48 PM
johni53's Avatar
I agree. I only have ever heard of one guy who burned up his engine because he NEVER changed his oil. Don't know how many miles he got but he went for a few years before his old Dodge van quit on him.
More interesting to me was how bad the quality of Fram filters were and how good the cheaper Wix were. Used to use them (Fram) all the time but have switched to the Mobil 1 filter with Royal Purple every 8k miles. Expensive at nearly $10 a qt but going longer between oil changes helps a little to offset the cost.
johni53 is offline
post #6 of 12 (permalink) Old 05-03-2013, 09:25 PM
Had an Plymouth Peon years ago. Put 175,000 miles on it, with just 2 oil changes! That engine never knocked, smoked or died on me (aside from a bad fuel pump). Diametrically opposed to that, I would change my Cadillacs' oil every 600 miles!!! (From indifference to ocd)
gjones is offline
post #7 of 12 (permalink) Old 05-04-2013, 05:39 AM
HP11's Avatar
Quoted: 24 Post(s)
Originally Posted by johni53 View Post
.....snip.....Expensive at nearly $10 a qt but going longer between oil changes helps a little to offset the cost.
Buy it at WalMart, Costco, or Sam's Club. About $5 per qt. at those places.
HP11 is offline
post #8 of 12 (permalink) Old 05-04-2013, 06:50 AM
FRAM's been around a long long time. The best filter? No, it's average like Purlolator and a few others. Why would someone put an average filter on a performance motor is beyond my ciphering. Buy and expensive piece of equipment then chince on the life blood to save a few $$ is just dumb.
NAPA filters are made by WIX. WIX is Dana. WIX, Mobil, or K & N are the top choices. 13.00 for K&N is salty, so is repairing a motor due to oil neglect or shoddy maintenance.
Years ago I picked up on Amazon K&N filters for 5.99 each. I purchased about 8 or so and got free shipping. Watch Amazon for deals like this.
post #9 of 12 (permalink) Old 05-04-2013, 06:23 PM
jpalamar's Avatar
As bad a rep as Fram has... I'm yet to see them sued all the time for engine failures. They clearly work just fine.
04 GTO - sold
jpalamar is offline
post #10 of 12 (permalink) Old 05-06-2013, 12:40 PM
BWinc's Avatar
Look everywhere. I picked up 5 Wix filters from Autozone at $5 a pop.
Current: MGW-p, H-pipe, SS OTRCAI, Lovell rear springs, Eliminator shocks and Pioneer AVH-P3300BT, JBA LTs+catless mids, Drilled/Slotted rotors, Kooks Afterburners, catch can & Tune Next: ??? Wish list: Intake & TB, modest cam, UDP, gears
BWinc is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Ebartone
Walmart is now selling the Bosch Distance oil filters batmans Service, Maintenance and Technical Discussion 2 12-19-2011 01:20 PM
AMSOIL Releases New Line of Extended Life Oil Filters Subdriver Service, Maintenance and Technical Discussion 16 02-02-2006 07:31 PM
Quick question about oil filters ModBoss2 Service, Maintenance and Technical Discussion 13 11-18-2005 06:00 PM
