Oil Pressure Sending Unit Plug - Pontiac GTO Forum
post #1 of 8 (permalink) Old 10-26-2015, 05:35 PM Thread Starter
doww301's Avatar
I was removing the rear hoist bracket to install a fast 102 and I accidentally broke the 3 pin female plug that goes into the oil pressure sending unit. I found a replacement plug at parts geek, but the wires aren't color coded like the factory three wire harness. There is a green wire, a yellow and green wire and a brown and white wire. I need to know which wire goes to the single plug that is closest to the snap connector, and also which ones go to the bottom left and right connections. Any help would be greatly appreciated as this is not covered in the shop manuals. Thanks in Advance!!
doww301
06 GTO: GMPP Ported LS3 heads, CamMotion Custom Grind Cam, 102/102, OTRCAI, JBA longtubes & catless mids, 3600 Vigilante T/C, G-Force Engineering Drive Shaft, Driveshaft Shop Rear Axles.
95 Z - Intake, Exhaust, Cooling, 3.73 gears, PCM tuned.
doww301 is offline
post #2 of 8 (permalink) Old 10-28-2015, 11:53 AM
Oh this would have been so easy last week when I had the top off my engine. I'll see if I can find out.
post #3 of 8 (permalink) Old 10-28-2015, 12:09 PM Thread Starter
doww301's Avatar
Muchas Gracias
Thanks Jerry!!!
doww301 is offline
post #4 of 8 (permalink) Old 10-29-2015, 03:30 PM
I made my best effort. If you had asked last Thursday I could have easily told you. My FAST manifold almost covers it and I tried an inspection mirror and squeezing my hand back there. No go. Sorry.
post #5 of 8 (permalink) Old 10-29-2015, 11:21 PM Thread Starter
doww301's Avatar
I really appreciate your trying!!
Thanks Svede, I appreciate your trying-Have a good one!!
doww301 is offline
post #6 of 8 (permalink) Old 10-30-2015, 09:34 AM
At the plug, aren't they laid out flat left to right, 1-2-3? Can't you just match them up as they come off the plug??
post #7 of 8 (permalink) Old 10-30-2015, 11:03 AM
AlaGreyGoat's Avatar
These may help:
Larry
Name:	Engine Oil Pressure (EOP) Switch Connector.gif
ID:	66866   Click image for larger version
Name:	Engine Oil Pressure (EOP) Switch Schem.gif
File Type: txt Engine Oil Pressure (EOP) Switch Pin-Out.txt (242 Bytes, 47 views)
AlaGreyGoat is online now
post #8 of 8 (permalink) Old 11-01-2015, 11:34 PM Thread Starter
doww301's Avatar
Thanks for the wiring diagrams. I will look at these and figure it out.
Again, Thanks!!!
doww301 is offline
Temp sending unit ZackD1212 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-09-2015 05:57 PM
oil pressure sending unit qwkvet 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 04-11-2015 02:34 PM
Fuel sending unit Piedog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 04-09-2013 09:14 AM
Need 1965 Oil pressure sending unit (sensor) iufan993 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 07-18-2012 05:46 PM
What is the differance fuel sending unit 67 Lemans John 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-22-2008 03:49 PM
