oil pressure warning. - Pontiac GTO Forum
post #1 of 11 (permalink) Old 01-24-2013, 04:21 PM Thread Starter
Grambo427's Avatar
I just bought an 06 and when I get in the the throttle (3/4 to WOT) the check oil light comes on. Has anyone else run into this? I'm new to not having a factory oil pressure gauge and don't wanna risk damaging the engine. Any advice for a rookie install on an aftermarket gauge? Any help is much appreciated.
Grambo427 is offline
post #2 of 11 (permalink) Old 01-25-2013, 11:40 AM
68OldGoat's Avatar
Welcome to the interesting world of GTO's. More info on your new ride (color, tranny, mods and etc.) would be helpful.... or even a pic or 2.
The first thing I would do for your present problem is check the oil for proper level .... or better yet, change your oil. Your oil light problem is not a common problem with these cars
I agree that it would be nice to have some gauges. There are a lot of gauges available for the 04-06 GTO's (they aren't cheap). If you want to look into getting gauges try;
South Coast Speed & Sound
68OldGoat is offline
post #3 of 11 (permalink) Old 01-25-2013, 11:51 AM Thread Starter
Grambo427's Avatar
thanks for the knowledge. I had just changed the oil yesterday afternoon and the light still comes on. Gonna look into testing the pump and start trying to diagnose the issue. hopefully it's not major.
It's a red '06 M6 with a CAI and exhaust ( cat back). As far as I can tell no other performance mods were done.
post #4 of 11 (permalink) Old 01-25-2013, 11:58 AM Thread Starter
Grambo427's Avatar
maybe it's the weather too. it's bitter cold here right now and I only drive it on the weekends.
post #5 of 11 (permalink) Old 01-25-2013, 02:50 PM
jpalamar's Avatar
What is the exact message your getting on your cluster?
04 GTO - sold
jpalamar is offline
post #6 of 11 (permalink) Old 01-25-2013, 04:21 PM Thread Starter
Grambo427's Avatar
the exact message is check oil and a beep.
post #7 of 11 (permalink) Old 01-25-2013, 04:30 PM
you're sure the oil is full? sounds like the pump is running out of oil when your reving high, only things I can think of that would cause that is too thick of an oil, oil level low, or clogged oil return holes. I'd temporarily hook up a oil pressure gauge and read the actual pressure.
post #8 of 11 (permalink) Old 01-25-2013, 05:11 PM Thread Starter
Grambo427's Avatar
it's running 5w30 and just changed the oil yesterday. so i'm thinking the same things. if i disonnect the sending unit from the comp to temporary a gauge will that throw it off or will it just reset when i plug it back in?
post #9 of 11 (permalink) Old 01-25-2013, 05:50 PM
should be fine, your warning light will be on of course. I rembered one car did about the same thing and the pick-up screen had fallen off the pump.
post #10 of 11 (permalink) Old 01-25-2013, 06:03 PM Thread Starter
Grambo427's Avatar
thanks for the advice. i'll get that done soon and check it out.
75 mph Overspeed warning BlackSheep 2004-2006 GTO General Discussion 21 06-02-2016 05:39 PM
How To: DIY OTRCAI (warning 56k) svede1212 Intake and Exhaust Discussions 73 10-18-2011 02:53 AM
Oil Pressure Warning Solved? Larry57Savoy Service, Maintenance and Technical Discussion 2 05-16-2011 11:53 PM
Hid warning!!!!! LITTON82 Exterior Discussions 19 11-19-2010 07:22 AM
Warning! Bad car wax! danrieke Exterior Discussions 23 10-19-2005 07:16 PM
