Oil Pressure Warning Solved? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-16-2010, 07:21 PM Thread Starter
Larry57Savoy's Avatar
Great site here! I saw on this forum a few months back that a bad sending unit could make the oil pressure deal come on. Well, I changed the sending unit(original was aluminum, replacement was brass and much bigger and heavier). Now my 06 does not throw the low oil warning. I think I'll still run it around up to temp and remove the sender and screw in my gauge and see.
Too many stories on here of oil pressure lock ups.
Also, why does my 06 sometimes reject 2nd gear until I put it into 3rd, then back to 2nd? That sucks.
Thanks for any input.
Larry57Savoy is offline
post #2 of 3 (permalink) Old 12-17-2010, 03:31 PM Thread Starter
Oops, I meant oil pressure switch.
post #3 of 3 (permalink) Old 05-16-2011, 11:53 PM
Hey, Larry.
Resurrecting a really old thread here; thought the q's might be worth answering for the knowledge base. I suspect the CAGS or "skip shift" is trying to force a 1st to 4th shift at lower speeds/lighter loads. It can be disabled a couple of different ways.
I'm not well versed on the oil pressure thing at all. Can't help ya' there.
MMike
MountainMichael is offline
no oil pressure wingnutooa 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 19 02-14-2009 01:52 PM
Engine oil warning light joeyk97 Service, Maintenance and Technical Discussion 11 09-12-2007 07:49 PM
Oil Pressure Gauge ACR 2004-2006 GTO General Discussion 7 12-03-2006 11:21 AM
Oil Service warning. Justice Service, Maintenance and Technical Discussion 2 04-05-2006 09:33 PM
Oil Pressure Gauge stl_head Service, Maintenance and Technical Discussion 6 03-02-2005 06:14 PM
