Oil service 04' - Pontiac GTO Forum
post #1 of 7 (permalink) Old 09-21-2013, 04:12 PM Thread Starter
Quoted: 6 Post(s)
Oil service 04'
If the oil service screen comes on a few times will it shut down the car. It did on mine. When I reset the service indicator the car started.
johnfin is offline
post #2 of 7 (permalink) Old 09-21-2013, 06:08 PM
I've never heard that one before.
GotTogO is offline
post #3 of 7 (permalink) Old 09-27-2013, 03:45 PM Thread Starter
Quoted: 6 Post(s)
Bcm
Well, it looks like the BCM, although its new. Called the dealer who has the full history on the car and had replaced the BCM and they said its a security issue, security light is blinking when its not starting. Its under an extended warranty and its covered (they said) so I hope it can be fixed and my starting problems ended.
johnfin is offline
post #4 of 7 (permalink) Old 09-28-2013, 10:49 AM
Have them check BCM wire bundle chaffing
post #5 of 7 (permalink) Old 10-07-2013, 03:00 PM Thread Starter
Quoted: 6 Post(s)
BCM problems
If this non-start problem has only happened twice in a year (car eventually started) should I have the dealer probe and fool around with my car (said they would do it for free). I dont want them to screw it up worse and it seems like a very technical issue and if the mechanic is not a programming master with a history back to 2004 that could be a problem. Any thoughts.
johnfin is offline
post #6 of 7 (permalink) Old 10-07-2013, 03:14 PM
Print up a copy of the sticky on BCM wire chaffing and bring it to them with the car. Anyone with a screwdriver should be able to check it out.
post #7 of 7 (permalink) Old 10-14-2013, 02:15 PM Thread Starter
Quoted: 6 Post(s)
Errors
Took it to the dealer and they said they found no codes in the BCM but some in the Gauges. They are stumped and said since it varies from a typical GM car they will have to make some calls to GM.
johnfin is offline
Service oil soon TxSoldier6.0 Service, Maintenance and Technical Discussion 10 04-22-2011 10:48 PM
Engine Service Oil New2thefamily Service, Maintenance and Technical Discussion 25 10-01-2010 04:04 PM
Service engine oil? Luvmycar Service, Maintenance and Technical Discussion 2 12-06-2009 01:41 PM
service engine oil smokin455 Service, Maintenance and Technical Discussion 7 11-23-2006 09:01 PM
Service Engine Oil GTOgator Service, Maintenance and Technical Discussion 12 02-20-2006 12:51 PM
