overheating maybe water pump? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-12-2013, 02:15 PM Thread Starter
2005 gto ls2 temp was spiking until got temp warning light and service oil light then car shut off had it towed to chevy they thought it was a blown head gasket but were not sure. It has always leaked coolant from the bottom of the reservoir when radiator is above 3/4 full. Replaced thermostat and radiator cap and still overheating especially at idle, when it's hot I cant even squeeze the lower hose by the thermostat. Could it be the water pump not producing enough pressure to open the thermostat?
zmanrollin is offline
post #2 of 3 (permalink) Old 10-12-2013, 03:24 PM
Thermo opens by temperature not pressure. Water pumps generally fail by leaking. Having it overheat, oil light and shutting off doesn't sound good at all. Read my timing chain thread. Just having that break took $1,000 in parts. GM service is going to rape you if they have to tear into the engine. Good luck.
post #3 of 3 (permalink) Old 10-13-2013, 09:50 AM Thread Starter
Timing chain is fine and yea GM wanted 1500-1700 if it was a head gasket but ran it with the radiator cap off and only hot air was coming from the upper hose making the coolant boil so I'm going to see if its the water pump and go ahead and replace it with an edelbrock high performance one and see if that works. If not then I'm going to go ahead and tear the motor down and put in a cam and machine the h re ads
'69 water pump Q etewald 1964-1974 Tempest, Lemans & GTO General Discussion 2 06-15-2012 12:56 PM
fit smaller water pump pully to stop overheating fiesta62 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 20 12-28-2011 03:22 AM
water pump Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 03-06-2011 12:27 AM
water pump Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 11-22-2010 01:02 PM
water pump questions , again 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 06-07-2010 10:26 PM
