P0300, P0174 check engine codes, rough idle, smell - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-18-2014, 05:18 PM Thread Starter
Hey guys just looking for some information and help if possible. 4 months ago I replaced the o2 sensor due to the same issue and now randomly 4months later the same issue. The car is running too lean smells awful at times, idles really rough at a stop, and is getting poor gas mileage again. The first code is a random misfire, 2nd is bank2 system too lean. Any ideas? Thanks.
BlueBeast85 is offline
post #2 of 3 (permalink) Old 04-26-2014, 08:02 PM
check the converter on bank 2,, chances are that the converter is clogged and the first sensor and second sensor is not getting correct info ,, telling the engine to back off on fuel ,,, pull the covert and check it ,, mine was broke and caused it to clog obvious, some times you might have to do the water test ,, gmonde
gmonde is offline
post #3 of 3 (permalink) Old 05-11-2018, 06:01 PM
Cooper06's Avatar
My car is doing similar things what eventually fixed your car? I’ve tried everything MAF sensor o2 sensors new plugs wires etc
Cooper06 is offline
Rough Idle Lanceth101 Drive train, suspension, alignment and brakes. 3 11-16-2013 03:58 PM
Does diablosport predator display check engine light codes? BlueDevilGoat Engine Tuning 4 03-19-2011 03:02 PM
Rough idle BLUE04 Service, Maintenance and Technical Discussion 1 01-26-2011 08:50 AM
check engine light codes question dustyminpin 2004-2006 GTO General Discussion 2 02-24-2009 07:13 AM
Rough idle???? kanibal Service, Maintenance and Technical Discussion 14 08-18-2006 07:09 PM
