Parking brake will not stay engaged - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-19-2010, 08:29 AM Thread Starter
Help! I pulled into the school parking lot this morning and the parking brake will not stay engaged. I can pull it up but when i let go it just drops it dosent even click when i pull it up. Whats wrong with it? 04' M6.
GTOVALANCHE is offline
post #2 of 4 (permalink) Old 02-19-2010, 08:56 AM
jpalamar's Avatar
The e-brake I belive is drum style in the rear. There is a little bit of adjustment that can be done there, but if I remember right most of the adjustment you do form the e-brake handle itself in the car.
Sorry I don't have better info, my friend had this issue is fixed it himself, he told he it was needed adjusted.
04 GTO - sold
jpalamar is offline
post #3 of 4 (permalink) Old 02-19-2010, 10:08 AM
GM4life's Avatar
Your ebrake/park brake ratchet is broken. Maybe the spring popped out or the prawl broke.
GM4life is offline
post #4 of 4 (permalink) Old 02-21-2010, 03:16 PM
I have an 04 m6 as well and the same thing happened to me about 3 weeks ago, i took it apart to see what was wrong and there is a green plastic piece that was broken, not a big fix, just try to find another one from someone parting out a gto.
JMAC007 is offline
Parking Brake Clamp Koppster 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 03-08-2009 05:27 PM
64 Parking Brake Adjustment Koppster 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 01-20-2009 09:15 AM
Ever pull parking brake on at 80 MPH? vnamvet 2004-2006 GTO General Discussion 19 10-11-2005 09:29 PM
Parking Brake Clunk... GTO4ART Service, Maintenance and Technical Discussion 6 07-08-2005 04:38 PM
Parking Brake gogirl Service, Maintenance and Technical Discussion 9 01-23-2005 09:04 PM
