Pedders Rear Springs - Pontiac GTO Forum
post #1 of 12 (permalink) Old 05-26-2010, 07:29 AM Thread Starter
Rear Pedders springs installed, what a difference. Ride height went from about 22-1/2" to 24" (17" wheels) Car now sits up proper. Fender is no longer just above the tire. Factory springs do not give the proper height. Pedders is even cheaper. Dealer worked with me and I got em under warranty.
New rear seat covers. Dealer replaced as a goodwill gesture. It pays to have a good rapport with the dealer. Jones in Lancaster, PA
post #2 of 12 (permalink) Old 05-27-2010, 09:47 AM
Sounds like you got the "stock height" springs... I need to do this soon this summer also, and was considering Pedders +5/16" drag springs. My front bushings are shot too, I'm probably going to spend the extra $$$ and get poly bushings so that it's a "fire & forget" repair.
Poncho Dan is offline
post #3 of 12 (permalink) Old 05-27-2010, 11:19 AM Thread Starter
Yup the stock height. Car sits up nice. I examined the front end while it was on the lift.... Plenty of distance between struts and tires the bushings are fine struts are in proper alignment. BIG difference between stock springs and Pedders.
post #4 of 12 (permalink) Old 06-05-2010, 04:27 PM
The rear shocks should get replaced too as the stock ones are total weak sauce. Glad you hear your happy altho I like my 20mm (3/4") drop springs better than the stock height. Also Lovells springs have the same spring rate at a lesser price if that's important (like with me )
post #5 of 12 (permalink) Old 06-07-2010, 08:47 AM Thread Starter
Thought about replacing the shocks but they are fine.. only 36K on them. I like the way it sits up. Handles better too. Although it looks like it sits up high its at the proper height. Looking at it sitting low and others cars, I didn't realize how much it sagged.
post #6 of 12 (permalink) Old 06-07-2010, 10:37 AM
KyleGT05usmc's Avatar
I need to find a GM dealer than can hook me up. but i live in military town so, opposite of that will happen.
everyone screws military in a military town... =[
K&N CAI, lightly ported stock TB/INT, JBA Hpipe, Spintech Side Exh. ([email protected] r/t .8800 60' 2.06)
1/13/10- Kooks 1 3/4, LS7 Clutch, B&M shifter
1/21/11 - Eibach Springs, Monroe Shocks, EBC Brakes
Soon - "Sungold" PowderCoated 17"s
KyleGT05usmc is offline
post #7 of 12 (permalink) Old 06-07-2010, 11:13 AM
GM4life's Avatar
That sux.
The dealership gives me discounts off of parts I order from them.
GM4life is offline
post #8 of 12 (permalink) Old 06-07-2010, 11:41 AM
You'd be amazed if you took the stock shocks off and tried compressing and expanding them by hand and then tried an aftermarket one doing the same thing. The stock one feels about as strong as a screen door closer. I replaced mine at about 20k
post #9 of 12 (permalink) Old 06-07-2010, 12:14 PM
GM4life's Avatar
Ditto. I know I was amazed how weak they were. I heard that they are weak but not that much.
GM4life is offline
post #10 of 12 (permalink) Old 06-07-2010, 01:41 PM Thread Starter
I'll be keeping a close eye on them and may replace them when I install the rip shifter... thanks
rear springs butchjr15 Drive train, suspension, alignment and brakes. 1 04-21-2010 07:44 PM
rear springs matt68gto 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 11 04-18-2007 06:19 PM
pedders springs GTJoe The Lounge 4 07-01-2006 03:55 PM
