Please Help New GTO headlights out! - Pontiac GTO Forum
post #1 of 3 (permalink) Old 11-21-2010, 08:50 AM Thread Starter
I just picked up a 06 m6 yester day with 1100 miles!! Unfortunately driving home I discovered that the headlights do not work There is no warranty from the dealer and honestly I do not even think they knew about it.
The brights work, the orange side lamp work, but not the fog and headlights; all of them.
Any suggestions on a quik fix? I was thinking that its probably a fuse but there is a separate on for each lamp and they are all out.
Rhinonm is offline
post #2 of 3 (permalink) Old 11-21-2010, 11:15 AM
RJ_05GTO's Avatar
If you do not know already to turn the fog lights on you pull the whole headlight button up. Just grab the button and pull outward. It would not be impossible for both of the low beams to be blown.
05 GTO A4- Svede otrcai, Fast 102, Livernois stg 2 ported heads, Texas Speed 224R cam, Pacesetter LT's, Edge 3000 stall, Kooks afterburners, Pedders 0 drp rear springs and shocks, MT et streets, 418rwhp/391rwtq, [email protected]
RJ_05GTO is offline
post #3 of 3 (permalink) Old 11-21-2010, 01:46 PM
REDGTO89's Avatar
Send a message via AIM to REDGTO89
The reason I think the fog lights did not work is because you had your brights on. but other wise hopefully its a easy fix like some light bulbs.
REDGTO89 is offline
05 GTO headlights New2thefamily Service, Maintenance and Technical Discussion 13 09-18-2010 05:52 PM
Need help with 68 GTO hidden headlights pops2 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 02-17-2009 10:39 AM
68 GTO headlights- how do they work? GTO394 1964-1974 Tempest, Lemans & GTO General Discussion 2 08-21-2006 08:51 PM
'68 gto vacuum headlights gto-pete 1964-1974 Tempest, Lemans & GTO General Discussion 2 11-29-2004 11:33 AM
