Please help! Sprung a leak! - Pontiac GTO Forum
post #1 of 6 (permalink) Old 09-03-2015, 08:27 AM Thread Starter
Please help,
I was pulling into my driveway, coming home from work, and noticed a funny smell. Peaking my head underneath the car, and it was leaking in two spots...
It seemed like it was leaking from the left and right bottom corners of the radiator. Is there a transmission line running along somewhere that I can't see?
The area where it's leaking in the first picture, looks like it coming from somewhere possibly tucked inside metal beam?
In the second picture, I know it's not leaking from the black line, but more so from the beam similar to the first picture.
Both spots were leaking pretty good until I parked the car, and shut it off.
I popped the hood, and couldn't see anything.
Thanks for any help!
2006 GTO, Cyclone Grey
Mods: Magnaflow Exhaust
Forum Poster is offline
post #2 of 6 (permalink) Old 09-03-2015, 03:38 PM
After you check the hoses the most common places to leak by far are the plastic end caps of the radiator. The water pump is number two.
post #3 of 6 (permalink) Old 09-03-2015, 10:32 PM Thread Starter
I ended up taking my car to my local mechanic, and they hooked a pressure gauge to the radiator. After adding pressure, the radiator immediately started leaking. It was leaking from the plastic mounting tabs near the top of the radiator, if I'm saying this correctly?
I was hoping it it was just a loose line, or a busted hose. They explained that it's not possible to just replace the plastic mounting tabs, but that the entire radiator will need to be replaced.
There you have it, a leaky radiator.
Solution: Replace radiator.
post #4 of 6 (permalink) Old 09-04-2015, 08:58 PM
It is fairly easy to replace and you can buy them online for $200 if you don't want an all aluminum one.
post #5 of 6 (permalink) Old 09-05-2015, 02:02 AM Thread Starter
Unfortunately, the repair shops around my area aren't very friendly with parts being purchased by the owner, and then having the shop do the installation. (Which is what I would have preferred to have done).
I had the work completed today, along with a few other things that needed replacing.
post #6 of 6 (permalink) Old 09-05-2015, 12:49 PM
Too bad. My point was it is a very easy DIY job you could do in a parking lot. I'll bet you paid in excess of $500
gto sprung trunk hinge mikey9743 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 06-03-2013 10:46 AM
A/C leak... Poncho Dan Service, Maintenance and Technical Discussion 2 06-04-2011 03:00 PM
gas leak Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 8 05-08-2011 11:37 AM
leak 04blueskys Drive train, suspension, alignment and brakes. 1 03-20-2011 02:33 PM
Sprung a coolant leak yesterday - weird Poncho Dan Service, Maintenance and Technical Discussion 17 05-26-2010 01:09 PM
