Power Outlet for Radar Detector - Pontiac GTO Forum
post #1 of 6 (permalink) Old 12-16-2004, 07:43 PM Thread Starter
OK, I just picked up my new 04 GTO last weekend, and noticed the other day that there's no Accessory Power Outlet anywhere near the dashboard for my Radar Detector! I happen to have a Val-One, so I can simply replace the coiled cord with a straight one, and plug into the outlet located in the center console.
But my question is this: does anyone know of an alternative location to tap into the electrical system so I don't have to run a cable across my center console and dashboard???
Thanks,
Will
dallascajun is offline
post #2 of 6 (permalink) Old 12-16-2004, 08:59 PM
My first mod was running a hard wire for my Valentine 1. I found an ignition 12v underneath the dash on the driver's side. It is an orange wire out of a plug with many wires. Slightly above it is a bolt I used for a ground. I pulled the windshield post trim loose and ran the wire from the left upper corner of the windshield down the post and behind the trim on the left side of the dash.
I have posted photos at: www.tanglewoodbrushstrokes.com
Go to Jerry's page.
jerhofer is offline
post #3 of 6 (permalink) Old 12-16-2004, 09:57 PM
Xman's Avatar
https://www.gtoforum.com/showthread.p...ghlight=outlet
check this option out. I'll send you some pictures if you provide me with your email.
Xman is offline
post #4 of 6 (permalink) Old 12-16-2004, 10:54 PM Thread Starter
GREAT!!! You can email pics to [email protected]. I'm looking forward to it.
Thanks,
Will
post #5 of 6 (permalink) Old 12-17-2004, 09:37 AM
Xman's Avatar
I finally figured out how to post pictures!!!
Xman is offline
post #6 of 6 (permalink) Old 12-17-2004, 05:12 PM
Power Outlets
You can find the connector end views and wiring info for all three power outlet locations as well as a schematic here.
Greg
GoatHerder is offline
