Problem with Short Fills at the Pump? - Pontiac GTO Forum
post #1 of 18 (permalink) Old 05-12-2005, 11:19 PM Thread Starter
b_a_betterperson's Avatar
Tried the fill the car up tonight. Could not get past 7/8ths of a tank. Anybody else experience this? Second time it has happened -- at two different stations -- and I've never has this happen with any other car.
b_a_betterperson is offline
post #2 of 18 (permalink) Old 05-13-2005, 04:34 AM
Xman's Avatar
This is a common occurance and has happened to me more than once. I researched it on the forums but don't remember what I found the was the potential cause. I was wondering if it was that particular pump sensing shut-off too early. When this happens, I just fill the tank back-up when it got low again.
Xman is offline
post #3 of 18 (permalink) Old 05-13-2005, 08:52 AM
The_Goat's Avatar
I've had this problem a few times, but usually just fill it slowly and listen hard until I think its close to full. Try pulling the nozzel up out of the hole so only about 1.5 - 2 inches is inserted.
First time I filled up I had the opposite problem. The pump didn't shut off in time and it sent gas about 6ft up in the air and back down the side of the car. I wasn't real happy...
The_Goat is offline
post #4 of 18 (permalink) Old 05-13-2005, 09:13 AM
On one occasion that happened to me and I think it was just the pump I was at.
GTODEALER is offline
post #5 of 18 (permalink) Old 05-13-2005, 02:21 PM
toolman's Avatar
Happens to me at certain gas stations, I just aviod those and fill up were it doesnt happen.
toolman is offline
post #6 of 18 (permalink) Old 05-13-2005, 02:28 PM
I get it, too. It seems that certain pumps just don't care for this car.
Duck916 is offline
post #7 of 18 (permalink) Old 05-13-2005, 02:38 PM
I think I've noticed this as well. I'm sure the inverted fill angle inherent with this car may be the culprit, though that's just a quick guess. I wonder if the country guys (without the fancy fume hardware) have the same problem?
Oh well, less fuel = less weight = more speed
bemeyer is offline
post #8 of 18 (permalink) Old 05-13-2005, 03:09 PM
I have the problem too. It happens more at certain stations than at others. I usually just pull the nozzle out and continue pumping.
UTLawyer is offline
post #9 of 18 (permalink) Old 05-13-2005, 04:41 PM
I get this alot too. Take a look at one of the pics in this thread on another board:
http://www.ls1gto.com/forums/showthread.php?t=25039
Go to the 13th picture down (not including pics in sig's), and take a look at the fuel filler tube! I think that twisted piece of comedy might be the reason for the problem.
-WW
wwroller is offline
post #10 of 18 (permalink) Old 05-14-2005, 02:24 AM Thread Starter
Thanks for the link. Always wanted to see where half the trunk went but didn't feel like fooling around with those nylon plugs.
No kidding on the fuel filler tube. What a mess.
