Proper ABS brake pad change - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-07-2014, 12:21 PM Thread Starter
Mike's06GTO's Avatar
I am concerned about changing the brake pads on my 2006. I have read that bleeding the fluid off while resetting the caliper piston is essential to prevent damage of the ABS system.
Is there a thread here that I have not been able to find which goes into detail?
I have never changed brake pads on a ABS equipped automobile before, and I am trying to do some research before beginning the job.
Michael.
Mike's06GTO is offline
post #2 of 2 (permalink) Old 09-07-2014, 11:41 PM
On my car I released the bleeder valve before compressing the callipers to avoid possible damage to the master cylinder, but I have changed the brakes on many ABS cars without releasing it and never had a problem. I am just very careful with mine because of the way I drive it. The brake job on my goat took me 4 times longer than on my Subaru. It took me longer because on the goat I used antisqueak, threadlock, silicone paste on slide pins, inspect and double check everything, replace brake fluid and bed the new brake pads in.
Qnko is offline
ABS (EBCM) Brake Pressure Modulator Valve Leaking... LS2 MN6 Service, Maintenance and Technical Discussion 1 08-06-2011 01:08 PM
Brake Pad Replacements.......... J.E.T. Service, Maintenance and Technical Discussion 15 12-30-2005 09:30 AM
Better Braking with a Pad change only! Xman Service, Maintenance and Technical Discussion 7 12-05-2004 01:07 AM
Brake pad options beertestr Service, Maintenance and Technical Discussion 1 10-26-2004 12:48 AM
