Rack & Pinion Rebuilds - Pontiac GTO Forum
post #1 of 2 (permalink) Old 08-14-2014, 12:00 AM Thread Starter
Just tried replacing my old rack & pinion unit with a rebuild from A1-Cardone. After 3 hours installing it (most of that time spent getting the first supply line attached) I started the engine to get fluid into the system and found a leak coming out of the top of the unit, where it connects to the steering shaft coupler. What a complete waste of time. I should have sent the unit back when I saw that they had slightly pinched one of the metal lines going across the rack, but thought they knew what they were doing.
I just wanted to post this in case anyone else was wondering about the quality of their rebuilds. Oh well. Another lesson learned.
Is anyone finding a better rebuild from AC Delco? It costs about twice as much.
mojimbo is offline
post #2 of 2 (permalink) Old 02-21-2015, 12:45 PM
I'm about to replace mine and was wondering if you used a thred on here or how you went about doing it
Brandonperry is offline
Rack and Pinion help '06 Clever Username Service, Maintenance and Technical Discussion 2 03-10-2014 02:01 PM
Rack and pinion and other components rebellious Drive train, suspension, alignment and brakes. 1 08-01-2013 08:08 AM
Rack and Pinion Steering Jim 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 8 12-31-2011 10:17 AM
Rack N Pinion KarLvr 1964-1974 Tempest, Lemans & GTO General Discussion 7 11-14-2010 07:11 PM
Rack and pinion in a 67? Need help bagged67 1964-1974 Tempest, Lemans & GTO General Discussion 6 03-22-2010 04:38 AM
