Radiator Cooling Fan - Pontiac GTO Forum
post #1 of 6 (permalink) Old 03-17-2010, 08:33 AM Thread Starter
My 2004 6 speed GTO's radiator cooling fan won't stop running when the car is off and its draining my battery. What's the problem? Need Help ASAP!!!
GOAT
Landover, MD
Jermaine is offline
post #2 of 6 (permalink) Old 03-17-2010, 08:39 AM
GM4life's Avatar
Locate the relay in the fuse box for the fans under the hood. Give it some taps and see will it stop it.
GM4life is offline
post #3 of 6 (permalink) Old 03-17-2010, 08:41 AM Thread Starter
Ok Thanks!!!! Hopefully this will work. I will let you know.
Jermaine is offline
post #4 of 6 (permalink) Old 03-17-2010, 08:55 AM
GM4life's Avatar
I figure I give you the simple place to start atleast. The fans are controled through the ECM. The relays are the electrical switch for them. A trip to the dealer to connect to the computer would be the next step, there is only one sending unit that tells the engine temp to the ECM. Good luck.
GM4life is offline
post #5 of 6 (permalink) Old 03-17-2010, 10:19 AM Thread Starter
GM4Life. You are the man....It worked bud!!! Thanks
Jermaine is offline
post #6 of 6 (permalink) Old 03-17-2010, 11:12 AM
GM4life's Avatar
GM4life is offline
Radiator Fan Shroud Three Deuces 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 01-16-2010 02:16 PM
cooling fans RJ_05GTO Service, Maintenance and Technical Discussion 1 04-30-2009 03:51 PM
radiator fan shroud for 67' GoToIt 1964-1974 Tempest, Lemans & GTO General Discussion 1 11-25-2007 11:42 PM
Cooling Fan wiring speedwrenchx10 Service, Maintenance and Technical Discussion 2 06-08-2006 09:14 PM
