radio stays on... - Pontiac GTO Forum
post #1 of 22 (permalink) Old 09-27-2010, 10:51 PM Thread Starter
radio stays on...
just purchases a 2006 goat today it has 55000 miles and i notices when i got out of the car and locked it the radio remains on. i tried starting it up and truning it off and locking it again it did the same. i then pressed the off button on the radio and locked the car but the radio light is still glowing anyone have any ideas??
gtousmc is offline
post #2 of 22 (permalink) Old 10-05-2010, 09:20 PM
Turn off the radio and lock the car as normal.
If the door unlocks itself in an hour,your ignition lock is stuck.
Spray some graphite in it.
If it doesn't work you might need a new lock.
nOObiE do0 is offline
post #3 of 22 (permalink) Old 10-05-2010, 11:37 PM
AlaGreyGoat's Avatar
When you remove the key, the plate at the switch pops out
and this turns off the Accessory side of the switch. If
it stays in, gently tap it with your finger to get to pop out.
Leaving the key in the switch while in the car is accessory mode.
Also, while in the car with the key out, you can turn on the radio to get to accessory mode. It will let you listen to the
radio, run the windows and power the 12 volt power
receptacles for about 20 min.
Larry
AlaGreyGoat is offline
post #4 of 22 (permalink) Old 10-06-2010, 08:43 AM
I'm having this same problem tried the graphite and nothing....
gtofred is offline
post #5 of 22 (permalink) Old 10-06-2010, 02:22 PM
talked to a guy from a shop and he told me that the door jamb switch was bad, he had the same problem in a caddy im gonna go to dealer and grab a new switch and see if it works keep you posted
gtofred is offline
post #6 of 22 (permalink) Old 10-06-2010, 02:43 PM
HP11's Avatar
Quoted: 24 Post(s)
I don't know about that. I think you'd be wasting you money on that switch. Opening the door doesn't turn off the radio in a GTO. Removing the key from the ignition does.
HP11 is offline
post #7 of 22 (permalink) Old 10-06-2010, 03:01 PM
ok good point ill look into that
gtofred is offline
post #8 of 22 (permalink) Old 10-06-2010, 03:10 PM
HP11's Avatar
Quoted: 24 Post(s)
My guess is that your answer lies somewhere in what AlaGreyGoat says in post #3.
HP11 is offline
post #9 of 22 (permalink) Old 10-07-2010, 07:29 AM
this might be a real dumb question but, seeing as how im new for a week to the gto world... Are the clock and odometer supposed to stay on after closing and locking up the vehicle????
gtofred is offline
post #10 of 22 (permalink) Old 10-07-2010, 07:32 AM
HP11's Avatar
Quoted: 24 Post(s)
The odometer, yes. I don't have the OEM radio so I don't recall if the clock stays on or not.
HP11 is offline
Traction Control stays OFF all the time bluerex Service, Maintenance and Technical Discussion 14 08-04-2016 12:28 PM
Pontiac 1968 GTO problem, Gen indicator light stays on Nummy22 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 15 09-18-2010 01:13 PM
Radio stays on? socalgto05 2004-2006 GTO General Discussion 12 02-01-2010 02:31 PM
No FM radio?!!? jpalamar Interior Discussions 8 12-17-2009 03:52 PM
Help with radio? tkinion 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 8 07-25-2005 11:31 AM
