Radio ticking - Pontiac GTO Forum
post #1 of 7 (permalink) Old 01-29-2014, 12:29 PM Thread Starter
Quoted: 6 Post(s)
Radio ticking
Ok, my radio ticks on the AM stations....kinda like in the old days with the coil interference BUT.....my key is off and the engine is not running. Whats the deal?
johnfin is offline
post #2 of 7 (permalink) Old 01-29-2014, 01:16 PM
Your radio will play for a few minutes or so when the engine is shut off key in off position. It will shut off when the door opens.
Does it do this all the time?
post #3 of 7 (permalink) Old 01-29-2014, 01:51 PM Thread Starter
Quoted: 6 Post(s)
noise
What does this have to do with a ticking noise?
johnfin is offline
post #4 of 7 (permalink) Old 01-29-2014, 05:37 PM
the ticking sounds like interference? doesn't do it on FM? You said it does this with the engine off and key in off position. It doesn't do it when the car is running with an AM station tuned in?
post #5 of 7 (permalink) Old 02-06-2014, 11:32 PM
my 04 GTO has this problem. AM only, with engine running or not. I even changed out the radio in an attempt to correct but it's still there. Is this a common thing? I also have an '05 but it doesn't do it. Is it perhaps just poor antenna reception?
Txgoat is offline
post #6 of 7 (permalink) Old 03-01-2014, 10:31 AM
pocketmaster's Avatar
Definitley sounds like interferance. Especially if its not doing it on the FM frequencies. If it has only recently started doing this I might suggest possible chaffing on the antenna cable. I know you would think if it were that then the FM frequencies would be affected as well, thats not the case because the FM frequecnies are not as susceptible to frequency fluctuation as the AM stations. Just a thought
God Bless Billiards!!!!
pocketmaster is offline
post #7 of 7 (permalink) Old 03-04-2014, 04:27 PM
it sounds like old fashioned radio interference that might have come from spark/coil/distributor but the fact that it doesn't increase with rpm's and it still does it with the engine not running says it has nothing to do with the motor. It is most noticeable on weak AM signals but that may be because the stronger signal may drown it out.
Txgoat is offline
loud ticking zacGTO05 Service, Maintenance and Technical Discussion 4 03-20-2012 04:08 PM
ticking sound simmons68 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-30-2011 01:17 PM
Ticking Noise.... pwned 2004-2006 GTO General Discussion 16 05-25-2009 09:56 PM
loud ticking... Capo 2004-2006 GTO General Discussion 12 04-20-2005 02:05 PM
Engine ticking Todd6790 Service, Maintenance and Technical Discussion 3 02-21-2005 08:55 AM
