ran over a deep puddle and gto puttered and wont start up - Pontiac GTO Forum
post #1 of 14 (permalink) Old 12-29-2010, 01:14 AM Thread Starter
Puddle is on the passenger side.
Immediately the check engine light kick on, engine was bogging so bad that I was steping on the gas to keep the idle up for a few seconds hoping that the symptoms would go away.
Underneath the hood the engine bay is dry.
Then I tried to turn it back on and the starter won't even try to turn the engine. Just dead.
Only thing that I can think of is my O2 sensor got dumped on with cold water and the thermo shock may have cracked the porcelin insulator.
Any thoughts?
My Youtube Channel
Supercharged (Roots) 6.0 GTO
Supercharged (Twin Screw) 3.0 NSX
Supercharged (Centrifugal) 4.3 S-10
batmans is offline
post #2 of 14 (permalink) Old 12-29-2010, 04:25 AM
87GN06GTO07IRL's Avatar
It will be tough to tell what got wet and caused this. Let it dry for a day or two and you should be ok.
87GN06GTO07IRL is offline
post #3 of 14 (permalink) Old 12-29-2010, 07:08 AM
this reminds me of my 07 dodge Ram 2500 with a cummins. if you hit a deep pot hole or a curb, you could get the wiring harness caught in the fan blades
as far is the GTO, could have knocked a wire loose, or dropped a plug somewhere in there. give some gental tuggs on the various places where the wire loom goes just to make sure everything is connected still.
motoristx is offline
post #4 of 14 (permalink) Old 12-29-2010, 07:57 AM
jetstang's Avatar
Local guy with a supercharged vette did the same thing and hydrolocked the motor, but Vettes intakes are real low. Good luck. Doesn't sound like 02s, if they got hurt the car would throw a CEL and run in default mode.
Burning rubber since 1982!!
jetstang is offline
post #5 of 14 (permalink) Old 12-29-2010, 09:30 AM Thread Starter
I'll have the mechanic take a look at the CEL today.
I didn't think of the knock sensor. Where is that located?
I doubt hydro lock since the puddle was no more than 5 inches deep and there wasn't even a single drop of water near the intake or entire engine compartment.
My Youtube Channel
batmans is offline
post #6 of 14 (permalink) Old 12-30-2010, 03:15 PM Thread Starter
Any chance that I may have hydro locked my LS2 with the Lingenfelter CAI?
If so what are the symptoms?
The starter should at least make a noise/movement instead of just being dead right?
My Youtube Channel
batmans is offline
post #7 of 14 (permalink) Old 12-30-2010, 04:15 PM
GM4life's Avatar
I beleave the knock sensor is on the passenger side of the engine just above the starter. You hit the puddle on the passenger side the intake is on the driverside.
I would pull the spark plugs and rotate the engine. Maybe some fuses or wires got wet.
GM4life is offline
post #8 of 14 (permalink) Old 12-31-2010, 12:18 AM
06BLACKGTO64's Avatar
Send a message via Yahoo to 06BLACKGTO64 Send a message via Skype™ to 06BLACKGTO64
I would start with pulling each fuse/Relays and make sure none blew out.. being it wont start id look at relays IMHO
06BLACKGTO64 is offline
post #9 of 14 (permalink) Old 12-31-2010, 07:44 AM
jpalamar's Avatar
Aren't C5/C6 intakes over the radiator style? He must of ran into a lake :-)
Since your starter isn't cranking, I would check fuses/relays first.
jpalamar is offline
post #10 of 14 (permalink) Old 01-02-2011, 03:39 AM Thread Starter
Knock sensor portion makes sense now due to the location.
My Youtube Channel
batmans is offline
Car Wont Start Help!!!!!!!!!!!! Vettekid1992 Intake and Exhaust Discussions 4 03-13-2010 11:30 PM
2004 GTO wont start laredo350 Service, Maintenance and Technical Discussion 1 11-29-2009 07:59 PM
car wont start 740tank Service, Maintenance and Technical Discussion 4 11-22-2009 01:48 AM
car wont start at all Musicmike927 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 10-30-2009 04:29 PM
Nice puddle of coolant under left front wheel ftlfirefighter Service, Maintenance and Technical Discussion 13 04-14-2006 04:07 PM
