Random idle surges in drive or reverse. - Pontiac GTO Forum
post #1 of 1 (permalink) Old 01-10-2016, 08:15 PM Thread Starter
I recently purchased an 06 A4 (had K&N CAI and some exhaust work done to it already. Stock otherwise) and noticed this strange problem. At random, when coming to a stop, the engine will sputter and nearly die, so I gotta put it in neutral and rev it. Does the same when I reverse into my driveway. Sometimes it just flat out dies. A/C is off btw. Has no issues cruising down the street, on the highway, or WOT. Looked through several GTO forums and found a few people with a similar issue and took the advice of the responses.. still does it. One day it's fine, the next day it's bad, etc. Also, have yet to see the CEL light up.
However, I noticed today, when I was rolling my window down to badge in at work, it bogged down once the window was maxed out.. I let go of the switch and the idle went back to normal. Pressed it again, held it for a couple seconds and the car died. Very strange. Maybe a bad ground somewhere? Anybody have anything like this happen to them before? If so, I'm all ears.
TXDMGoat is offline
04 random high idle problem? jessejames 2004-2006 GTO General Discussion 7 11-28-2016 06:20 PM
random pics of my YJ psycho1000r Exterior Discussions 16 05-23-2013 07:00 PM
Random misfires at idle. I'm stumped! Nightmare2003 Service, Maintenance and Technical Discussion 5 03-01-2011 07:10 PM
Random Thoughts fergyflyer The Lounge 19 12-31-2009 10:35 AM
Vehicle lowers and lifts in rear end when shifting from park to drive or reverse Goat Runner Service, Maintenance and Technical Discussion 4 07-30-2009 02:21 PM
