Real Main Seal and Oil Pan Leak - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-10-2013, 01:16 PM Thread Starter
I brought my car into GMC service for an oil leak and they said the leak is coming from the rear main seal and also towards the front where the oil pan is.
In order to service the oil pan GM says to pull the engine. How true is this?
Also, has anyone had either of these issues?
PatrickNJ is offline
post #2 of 3 (permalink) Old 11-24-2014, 01:18 PM
2006GOAT_GTO's Avatar
Yes for the oil pan you need to pull the engine or drop the subframe
2006GOAT_GTO is offline
post #3 of 3 (permalink) Old 11-24-2014, 02:11 PM
The oil pan gasket is the hard one. It's held on by two pop-rivets in addition to being sandwiched.
Transmission leak; whatís the best way to seal the pan? jimmy328 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 06-06-2012 12:36 AM
Is a rear main seal leak a big deal jtwoods4 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 02-17-2012 12:35 PM
67 GTO rear main oil seal use viton or best gasket fiesta62 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 10-13-2011 12:22 AM
1966 GTO Main Bearing Seal Leak Question take5 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 01-31-2010 04:06 PM
68 Gto Rear Main Seal Leak khinton 1964-1974 Tempest, Lemans & GTO General Discussion 16 03-14-2009 06:01 PM
