Rear diff question ?? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 02-21-2011, 02:30 PM Thread Starter
pocketmaster's Avatar
While changing the rear diff fluid I noticed two sensors that appear to be proximity sensors to either side of the diff case. What are these sensors ??
God Bless Billiards!!!!
pocketmaster is offline
post #2 of 6 (permalink) Old 02-21-2011, 05:29 PM
They are wheel speed sensors for the ABS
post #3 of 6 (permalink) Old 02-21-2011, 05:51 PM Thread Starter
Thanks svede1212. I just noticed them while i was checking the rear diff fluid. I just had a monster clutch installed and for some reason i get a small whining or winding sound now when Im accelerating from a stop or going fairly slow and then as I ease off the clutch and accelerate thats when I hear a brief winding sound. It sounds as if its coming from my tranny/clutch but cant really tell. I dont lose power or anything and the sound is only brief. Any suggestions....?
post #4 of 6 (permalink) Old 02-22-2011, 02:49 AM
thats transmission noise. it seems to get worse with a short shifter. i haven't found a way to quiten it down yet
motoristx is offline
post #5 of 6 (permalink) Old 02-22-2011, 06:27 AM
PM sent
post #6 of 6 (permalink) Old 02-22-2011, 06:31 AM
Do you know the history of the rear ends? Do you know of the issues with oil viscosity break down in the rear causing the clutches to bind causing humming, clunking, and other noises? Too many people point to the transmission when the rear ends had issues from factory and were found to be the culprit of mysterious noises.
Rear axle and diff PisnNapalm 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 09-28-2010 10:12 AM
Rear Diff. Tag Three Deuces 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 2 10-09-2009 10:48 AM
Rear Diff ID Jim 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 04-14-2009 07:12 PM
Torn on what to do with rear diff... DJ Dannis Drive train, suspension, alignment and brakes. 6 03-24-2007 03:16 PM
