Rear Differential Fluid? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-06-2015, 11:06 PM Thread Starter
Refractor's Avatar
I am going to be changing out my rear diff fluid here in a couple of days and wanted to see what type of rear diff fluid you guys are using? I was looking at using the Royal Purple 75W-90 with friction additive. 06 A4.
Stock LS2, Muffler Delete/Straights & More mods to come!
Refractor is offline
post #2 of 6 (permalink) Old 10-07-2015, 08:44 AM
Torco RGO 85w-140 and type "F" friction modifier. Dyno oil is recommended over synth. Another reason to use that is to fine tune the modifier over an all-in-one. Friction modifier makes the oil slipperier. Our posi uses cones that act as clutches. The modifier lets them slip smoothly when needed. Too little and they will grab and let go making a chatter or popping noise. Too much and the cones slip when they shouldn't. It's a bit more trouble but the best way is to add about an ounce and a half (2 ounces is "normal") and drive it a bit to mix and then do slow hard turns in both directions. If it's fine you're done. If it pops add a little more and repeat. The smallest amount that doesn't pop is the best for always getting two wheel burnouts.
post #3 of 6 (permalink) Old 10-07-2015, 05:36 PM Thread Starter
Refractor's Avatar
Seems like you know your stuff, thanks for answering my questions. I'll go ahead and buy the Torco & the friction modifier. So about less then 2qt's of Torco and how much of the modifier?
post #4 of 6 (permalink) Old 10-08-2015, 01:21 PM
Like I said start with 1 1/2 oz and add more if you get noise in the back on slow, hard turns in a parking lot. I'd have no more than 2 oz total
post #5 of 6 (permalink) Old 10-09-2015, 12:37 PM
doww301's Avatar
Toro Oil and additive
Unless you live near a torco dealer you can order the supplies you need from torcousa.com. You want the RGO 85/140 weight oil- NOT the synthetic stuff. It comes in a 1 liter bottle-you will need two. Also, you want the type "F" friction modifier, not the usual type "G" that GM rear ends typically use. Their stuff is very good- pricing is $12 per liter of RGO oil and $9.65 for a 4 ounce bottle plus a few bucks for shipping. I suggest that you also get a pump from your local parts store as you will not be able to add the oil with any type of funnel I've seen. The very bottom bolt is the drain plug and can be removed with a 13mm socket. The fill plug is at the upper right on the diff cover and requires a 30mm socket or a large adjustable wrench to remove. I would recomemend pumping in about 3/4 of the first bottle then adding 1.5 to 2 oz of friction modifier to that bottle and then finish pumping in all that remains. Switch bottles and finish filling up the diff. Replace the 30mm plug-DO NOT OVERTIGHTEN - just make it snug and you should be good to go.
06 GTO: GMPP Ported LS3 heads, CamMotion Custom Grind Cam, 102/102, OTRCAI, JBA longtubes & catless mids, 3600 Vigilante T/C, G-Force Engineering Drive Shaft, Driveshaft Shop Rear Axles.
95 Z - Intake, Exhaust, Cooling, 3.73 gears, PCM tuned.
doww301 is offline
post #6 of 6 (permalink) Old 10-26-2015, 11:49 PM Thread Starter
Refractor's Avatar
I just changed out oil 2 days ago, and so far this stuff is working great!
rear differential ID mcyphert 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 7 08-08-2015 09:02 AM
Rear differential gen. ?s IMCauley Drive train, suspension, alignment and brakes. 8 01-06-2011 08:15 PM
amsoil differential fluid question j3157 2004-2006 GTO General Discussion 6 01-05-2007 11:10 AM
