Rear end - Pontiac GTO Forum
post #1 of 8 (permalink) Old 12-20-2014, 07:25 PM Thread Starter
Quoted: 6 Post(s)
Rear end
Any of you guys retro fitted a real rear end into your GTO? The M80 is a real POS. Both Dana and GM have told me "good luck, you're on your own" with that one.
johnfin is offline
post #2 of 8 (permalink) Old 12-21-2014, 08:39 AM
Haven't done it yet. My POS has lasted 10 years with quite a few launches and up to ~480 RWHP so far. gForce has a 9" kit but be prepared to drop $4,300 plus install on it.
post #3 of 8 (permalink) Old 12-21-2014, 07:52 PM Thread Starter
Quoted: 6 Post(s)
rear end
My local Gm deal said they changed a bunch of these rear ends under warranty. ie they were young and junk. and.. mine is hosed. $4300 is unreal. You can get a complete moser dana 60 with axles(mopar) for $2000
johnfin is offline
post #4 of 8 (permalink) Old 12-21-2014, 08:29 PM
Welcome to the GTO world. Back when they were new 10 years ago a lot of people complained about them whining. That was before everybody swapped out their exhaust to make the car louder.
post #5 of 8 (permalink) Old 12-27-2014, 08:15 PM Thread Starter
Quoted: 6 Post(s)
can i drop the differential with the rear of the car on ramps? Not sure if the axles need to rotate to disconnect.
johnfin is offline
post #6 of 8 (permalink) Old 12-28-2014, 10:35 AM
You can. You just need to unbolt the half shafts from the stubs. The bolts holding the pumpkin are on the top along with the sway bar anchor and are a bit of a pain to get at but doable.
post #7 of 8 (permalink) Old 01-04-2015, 08:00 PM Thread Starter
Quoted: 6 Post(s)
Why do the manuals tell you to mark the drive axles before removing from the stubs? I dont see how this could be a balancing or assembly issue.
johnfin is offline
post #8 of 8 (permalink) Old 01-06-2015, 02:46 AM
I have removed mine twice already without marking anything and everything is fine.
Qnko is offline
rear end id jim w 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 07-23-2014 03:06 PM
Rear End Help Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 01-03-2013 01:00 PM
?- looking for new rear end gears and rear suspension whytedude422 Service, Maintenance and Technical Discussion 3 03-31-2010 03:11 AM
once again, rear end... PONTIACBEN 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 12-24-2007 10:29 AM
Rear End Langor Drive train, suspension, alignment and brakes. 2 11-22-2007 07:34 PM
