Recent oil change n seems like oil level creeps higher?..... - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-27-2010, 04:44 PM Thread Starter
I change my oil about 2 weeks ago on my 05 a4 goat and seems like when I check it the oil level on dipstick is showing it's going higher. The oil level is past the full line just a little seems like.
This user here in our forums said the same thing: QOUTE: mistermike-[Tech Spec] " My engine does just the opposite. Every time I check, there's more oil than before. I have to drain it down occasionally, and sell the surplus to Amsoil. "
So is it ok or do I drain some? Thanks
pctek is offline
post #2 of 3 (permalink) Old 09-27-2010, 06:30 PM
No... what's happening is either 1 of 2 things.
1. You're not giving the engine sufficient drain down time before you change the oil. Wait 20 minutes before draining the oil after running the engine to allow the oil in the cylinder head to make it down into the crankcase.
2. You're filling/topping off your oil to the full line on the dipstick without allowing drain down time.
In any case, you can probably be a full quart over (7.5qts) on the LS block and still be ok... most automotive engines can handle an extra half no problem.
And you're also finding out why LS1GTO is a weaksauce website
Poncho Dan is offline
post #3 of 3 (permalink) Old 09-27-2010, 09:58 PM Thread Starter
Hahha thanks, actaully seems like alot of activity over there too.
pctek is offline
check oil level, WTF aintmisbehavinn Service, Maintenance and Technical Discussion 14 08-03-2009 03:01 PM
Oil Change? SPICERED2006 Service, Maintenance and Technical Discussion 14 10-18-2007 01:19 PM
Oil Change easybucketz Engine Discussions 5 12-07-2006 01:07 PM
Oil Companies Testing Even Higher Prices b_a_betterperson The Lounge 31 10-11-2005 02:04 PM
Oil change? vnamvet 2004-2006 GTO General Discussion 5 09-21-2005 05:18 PM
