Removing the center console - Pontiac GTO Forum
post #1 of 11 (permalink) Old 09-15-2005, 01:09 PM Thread Starter
YouHolden?'s Avatar
Send a message via AIM to YouHolden?
My short shift is getting here tommorow, and I need to figure out how to remove the center console. Rather than slashing away at my cheap plastic, I thought i would be prudent and ask if anyone here can point me in the right direction. Can anyone help me out with this?
"A lot of people go through life doing things badly. Racing is important to men who do it well. When you're racing, its life...anything that happens before or after...is just waiting."
-Le Mans
YouHolden? is offline
post #2 of 11 (permalink) Old 09-15-2005, 02:38 PM
b_a_betterperson's Avatar
Remove the rubber insert in front of the shifter. The stuff that keeps change and crap from rattling around.
Then remove the single philips head screw located above it. You can see it no problem from the driver's side footwell.
Open the console storage compartment lid -- then pull up on the back end of the console plate. It will pop out with a decent tug. It's scary -- but it won't break.
When you get the back end up, reach under it and unplug the power window and T/C switches -- then keep working forward. It will eventually tilt up and lift out.
Can not stress that you'll need to be in the right mind set for this job. The bolts to remove the boot are underneath the car -- and a real pain to get to. Make sure you have plenty of connectors and extensions -- because you're going to need them. Make sure you have long sockets too -- because the bolts are short enough to fit a short socket on -- but long enough to kick the socket off when you insert the drive.
b_a_betterperson is offline
post #3 of 11 (permalink) Old 09-16-2005, 10:07 PM Thread Starter
YouHolden?'s Avatar
Thank you very much, everyone I've talked to, for all of your help. I finished my installation and just took it around the block.....
like a dreaM!
-Le Mans
post #4 of 11 (permalink) Old 09-16-2005, 10:08 PM
Premium Member
EEZ GOAT's Avatar
Send a message via Yahoo to EEZ GOAT
like a dreaM!
EEZ GOAT is offline
post #5 of 11 (permalink) Old 09-17-2005, 09:51 AM
Is there a significant improvement in the gear changes?
DeLandGTO is offline
post #6 of 11 (permalink) Old 09-17-2005, 03:44 PM
LS2FAST's Avatar
I did this mod as well... and YES, there is a significant difference. Very close ratio and all the slop is removed from the old shifter. It did take some getting use too (about a day) then you wonder why GM put a POS shifter in this type of car. Oh well, Thank you B&M!!
GMM Ripshifter w/MOMO knob, LPE CAI, 160 T-Stat, Hotchkis Sway Bars, SAP Grilles.
LS2FAST is offline
post #7 of 11 (permalink) Old 09-17-2005, 06:34 PM
vnamvet's Avatar
Could please take the time to instruct us in just what is involved?
Step by step, clearly. I would like to install the same or mabe a Hurst, and as one who has "been there before", you would help a lot of folks out.
Thank you.
vnamvet is offline
post #8 of 11 (permalink) Old 09-17-2005, 07:49 PM
http://www.bmracing.com/malloy/GTOinstructions.pdf
Download this PDF and read it. Step by step instructions with pictures. Will give you a real good idea of what you need to do. Access to the shifter boot retainer bolts from underneath the car is a big PITA (Steps 7 and 18), but when you're done -- man, is it worth it.
BTW, the only step I don't agree with in these instructions is 14. They recommend placing the RTV on the shifter base. To me, placing the RTV directly on the transmission is much more precise.
As for the unit itself -- fantastic -- although the feel through the center gate isn't all that great. More of a Tremec issue than a shifter issue.
post #9 of 11 (permalink) Old 09-17-2005, 10:07 PM
04m6_ca's Avatar
Yipee - me too
I put my B & M shifter in today too. What a difference.
04m6_ca is offline
post #10 of 11 (permalink) Old 09-18-2005, 05:33 AM
vnamvet's Avatar
THANK YOU! Exactly what I was looking for.
Thank you again. I always like to know what i am getting into PRIOR to install.
Craig
FL
vnamvet is offline
