Removing the factory radio? - Pontiac GTO Forum
post #1 of 8 (permalink) Old 09-07-2005, 07:38 AM Thread Starter
Is there anyway to remove the factory radio without buying some specialized tool? I just need to pop it out so I can get to the wiring thats behind it for the JHP guages.
Thanks,
Paul
Grey-Goat is offline
post #2 of 8 (permalink) Old 09-07-2005, 08:49 PM
Thanks,
Paul
Basically if you can put something slightly smaller than the hole into the holes about 2-3" or so you should be able to release the clips on the side of the factory radio. I used some roofing nails I had laying around and with a little wiggling the radio slid out.
vmax is offline
post #3 of 8 (permalink) Old 09-08-2005, 06:59 AM Thread Starter
Thanks... I'll have to try that.
post #4 of 8 (permalink) Old 09-08-2005, 09:23 AM
6QTS11OZ's Avatar
Sounds pretty good. I bet it sounds nasty at full throttle. And I mean nasty in a good way.
~I'm ya huckleberry~
~516rwhp/500rwtq~
6QTS11OZ is offline
post #5 of 8 (permalink) Old 09-08-2005, 10:09 AM Thread Starter
You can hear me coming, thats for sure!!
post #6 of 8 (permalink) Old 09-19-2005, 01:56 AM
Coat hanger rods bent into a "U" so you can put one in each side and pop em both at the same time works well.
Cheap "DIN" tools.
ShadesOfGrey
ShadesOfGrey is offline
post #7 of 8 (permalink) Old 09-19-2005, 08:42 AM
Cheap "DIN" tools.
ShadesOfGrey
Excellent suggestion!
vmax is offline
post #8 of 8 (permalink) Old 09-19-2005, 09:09 AM Thread Starter
What I ended up doing is buying one from Walmart. It was like 3 bucks... It was for a little radio so I just cut them in two... stuck em in the holes and pulled on the trim and the radio popped right out.
