Removing Stock Blaupunkt Radio 2004 GTO - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-06-2013, 01:27 AM Thread Starter
Hi, I tried removing my stock Blaupunkt radio syste, that came with my car, but as i removed it, the fuel gauge, speedometer, and traction control all werent working? Does anybody know why that happened right after i disconnected my stock radio?
Jondeleon94 is offline
post #2 of 4 (permalink) Old 09-06-2013, 11:04 PM
jwb5858's Avatar
I removed mine to wire up a bluetooth module and don't recall any connectors back there that could have have come loose. That however would be where I would start. Also check the wiring harness behind the glovebox on the right. It's been known to rub on the metal brace and cause a short.
Good luck.
jwb5858 is offline
post #3 of 4 (permalink) Old 09-10-2013, 09:08 PM Thread Starter
I went to the dealership and they said that there is a module inside of the Radio system that is connected to the speedometer, traction control, and fuel guage? Was he just talking out of his ass ?
post #4 of 4 (permalink) Old 09-11-2013, 09:21 AM
BWinc's Avatar
Did you disconnect the battery when you pulled the unit out? And check the BCM wires as jwb5858 suggested.
Current: MGW-p, H-pipe, SS OTRCAI, Lovell rear springs, Eliminator shocks and Pioneer AVH-P3300BT, JBA LTs+catless mids, Drilled/Slotted rotors, Kooks Afterburners, catch can & Tune Next: ??? Wish list: Intake & TB, modest cam, UDP, gears
BWinc is offline
Blaupunkt radio system problem goatsmom Interior Discussions 4 04-30-2012 09:23 AM
Stock Blaupunkt radio code kcox82 Interior Discussions 4 04-24-2009 05:52 AM
Stock 2006 GTO Blaupunkt Stereo CycloneGTO Interior Discussions 5 04-24-2007 09:51 PM
