replaced both front hubs now traction control turns off by its self - Pontiac GTO Forum
post #1 of 5 (permalink) Old 03-20-2016, 10:50 PM Thread Starter
i replaced both front hubs on my 06 now traction control turns off by its self & cruise control will disenguage while running down the road !
any ideas in this?
also installed a 7" touch screen at the same time.
xfasteddiex is offline
post #2 of 5 (permalink) Old 03-21-2016, 06:28 PM
If you have a problem with a speed sensor on a hub it may cause that. Check your ABS wires and connections on the hubs
post #3 of 5 (permalink) Old 03-30-2016, 09:01 PM Thread Starter
well driving home today my info center flashed check alt , abs & brake one right after the other . so i get home pull hot & ground term off cleaned them & put back on started & let run for 15 minutes traction control stayed on as it should & no other issues !
post #4 of 5 (permalink) Old 03-31-2016, 09:50 AM
Autozone hubs??
Scan the computer to see which hub is bad.
post #5 of 5 (permalink) Old 08-07-2016, 05:11 PM Thread Starter
finally figured it out ! had a blue tooth obd2 scanner plugged in to send info to my radio. took it out & in 100 miles now no issues!
Replaced Front control arm bushings GM4life Drive train, suspension, alignment and brakes. 3 10-17-2013 11:55 AM
Drum brake front hubs goatdriver66 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 02-21-2013 08:29 PM
Traction Control SleeperGoat Service, Maintenance and Technical Discussion 6 01-21-2012 07:08 AM
Traction control, still no traction :-) tummen 2004-2006 GTO General Discussion 14 08-22-2008 12:25 PM
