Replacing clutch fluid help - Pontiac GTO Forum
post #1 of 9 (permalink) Old 01-16-2011, 03:02 PM Thread Starter
pocketmaster's Avatar
While replacing my clutch fluid, afterwards I noticed clutch fluid under my vehicle. Check me if Im wrong, but the easiest way to replace your clutch fluid is to almost empty the clutch master cylinder, refill with new DOT 4 clutch fluid, replace the cap and pump your clutch 30 to 40 times and repeat untill your clutch fluid is clean. After I did that I noticed the clutch fluid on the ground. Any help or advice would be greatly appreciated....
God Bless Billiards!!!!
pocketmaster is offline
post #2 of 9 (permalink) Old 01-16-2011, 08:08 PM
If you are talking about the "Ranger Method" famous on Corvette boards for changing clutch fluid then yes, that's the easiest way to change the fluid. However your lines shouldn't leak.
I use the "Ranger Method" on my GTO (and Corvette) to keep my clutch fluid in tip top condition with no problems on either.
LS2 MN6 is offline
post #3 of 9 (permalink) Old 01-16-2011, 08:32 PM Thread Starter
Yes, thats the method I used. After carefull searching I guess some of the fluid must have dripped from the turkey baster while I was withdrawing the dirty fluid. I have been keeping a close eye on possible leaks, and nothing is seen and there has been no fluid loss. I was hoping replacing old fluid with new wouldn't cause leaks. Btw i like the color of your GOAT...sweet ride!
post #4 of 9 (permalink) Old 01-17-2011, 09:20 AM
The easiest way (and best) to replace clutch fluid is to have a remote bleeder on the slave and flush it from one end to the other. If you ever have any clucth work replace the slave and put a remote line on
post #5 of 9 (permalink) Old 01-17-2011, 11:13 AM
GM4life's Avatar
GM4life is offline
post #6 of 9 (permalink) Old 04-23-2011, 05:04 AM
dquack's Avatar
Send a message via Yahoo to dquack
I am going to use the Ranger method, but problem being I was only able to get DOT 4 fluid and not Super DOT 4. I know from reading the difference between the 2 is that Super DOT 4 has a higher boiling point. I am stuck in Germany and noticed the black fluid the other day. The car gets shipped back to the states in a month and a half. Will there be a big issue with just using DOT 4? Thanks in advance for any advice or tips.
2006 Black on black M6 - Cam, Supermaxx header system, valvetrain kit, L76 intake, L92 Heads, Volant cool air intake.
http://www.youtube.com/watch?v=-BgmGcv90RM
dquack is offline
post #7 of 9 (permalink) Old 04-24-2011, 11:14 AM
As long as it's NOT synthetic you're OK. I use a DOT 3/4 and have no issues. The black crud BTW is not "assembly lube" or anything from the clutch lines. It's clutch dust that gets introduced past the seal of the slave. The piston extends, dust gets on it, the piston retracts and a small amount of dust gets into the hydraulic fluid. Because of that waiting for the crud to work it's way ever so slowly to the reservoir to get it out isn't the best way. The heaviest concentration of it is at the slave end. That's why bleeding from the top to the bleeder at the end of the line is the best way. Remote bleeders make that really easy.
post #8 of 9 (permalink) Old 04-24-2011, 03:35 PM
GM4life's Avatar
Dot4 is fine. I think dot 5 is synthetic what you don't want. I flush mine often becuase of those black chunks in there what I think Ranger called out as clutch dust that gets past the slave seal.
GM4life is offline
post #9 of 9 (permalink) Old 04-24-2011, 03:58 PM
2005 GTO Manual:
What to Add
When you do need brake fluid, use only DOT-4 brake
fluid.
Use new brake fluid from a sealed container
only. See Recommended Fluids and Lubricants on
page 6-12.
Page 6-12:
Hydraulic Brake
System
Hydraulic Brake Fluid. Use only
GM Part No. U.S. 88958860, in
Canada 88901244, Super DOT-4
brake fluid.
where do you bleed clutch fluid roadracer Service, Maintenance and Technical Discussion 12 10-25-2016 07:49 PM
Clutch goes soft after driving spiritedly and other clutch related things Sciggy Drive train, suspension, alignment and brakes. 11 04-02-2011 01:01 PM
Air in clutch fluid or slave cylinder? SplitFire Drive train, suspension, alignment and brakes. 3 12-11-2010 12:21 PM
Amsoil DOT 4 the best brake & clutch fluid for the GTO? batmans Drive train, suspension, alignment and brakes. 5 06-03-2010 03:11 PM
Clutch Fluid canadianGTO 2004-2006 GTO General Discussion 5 11-15-2009 01:58 PM
